ok soa and have been having a bit of death wobble. running 39.5" bias iroks and havent had them balanced yet. went through the wheel bearings put new trunion bearings in when i did go soa(only a few months ago). did the backyard mechanic wheel alignment sent to 1/8" of toe in. what brings me to this is as you sit in the front and look at the tires on passenger the top tire sticks out and on the driver side the bottom is out. I put a level on the rim and i get a reading of 1.5 degrees in opposite ends. thus between the two i am out three degrees. did i screw up on my cut and turn. i did triple check it all but it seems my driver side spring perch sits a little lower in the front then the passenger side. also have read that collapsed trunion bearing may have an affect on this. Now if im wrong the only way to check is by tearing apart again. yes no. now if i didnt set enough caster into it which for the life of me i cant remember what i set it at would this affect it and i could easily fix this with the old caster shim. Ok all let me know if i am barking up the wrong tree and if there is anything else to do. Just redid the spring packs in the front due to a serious lean to driver side 3" and am going to get an alignment and hopefully tires balanced if no to pricey. Thans again all
Bryon
Bryon
