Today I pulled my front wheel off to check the fit of my steelies (they fit) that I’m installing soon. If anyone has an idea of who makes these discs and calipers I’d greatly appreciate some input. No issues right now just curious. Thanks
looks like standard issue mini truck stuff, solid rotor.
Ok thanks. Also is that a spacer or is that standard mini truck disc?
the entire Front Axles of both Mini Trucks and FJ40 land cruisers free wheel hub to free wheel Hub was Forged , Cast and Milled by the to
companies at the time whom now have Merged since as understand it to be , ASCO and AISIN
now fall under the bid watchful big brother of TOYOTA Motors Ltd. Japan and simply are now called AISIN
Well the right side is red AISIN. Kind of a mix and match.Color of the hub tells me that is from a 1979 4wd mini truck. Solid rotor and all.
