I have a 1973 fj40 I just did a motor swap to put the correct motor back in my cruiser. My issue is that my starter is not starting the engine. It will turn the motor a quarter turn and nothing more. It is acting like it is not getting enough power to turn the motor. Battery is brand new.
What I have tried already is,
1. New ground wire for battery cleaned up the ground and the bolt that holds it there.
2. Did a bench test of the starter at Auto Zone checked out good.
3. Cleaned the contacts on the starter to make sure got a good conection.
4. checked all connections with a meter to make sure they were really working.
5. Disconnected the alternator and all other connections to the battery except starter and fuse block.
I have tried searching but could not find anything on the problem. I may have missed something if so I appologize. I need help to get these motor started thanks in advance for the help
Ben
Ben
