Look closely down the right hand side of the timing chain passage. The chain tends to wear through the timing cover, and then the oil and coolant mix.
So I figured I'd prep for timing this motor and pull the valve cover. [snip] Thoughts??
LOL, just kidding. I did pick it up cheap so as of now I do not have that much invested. Looking down into the timing chain galley I can see the guides are intact and the timing cover is new. PO told me he did new guides and timing cover and of course I can see its new just by looking at it as its bright aluminum compared to everything else. I am going to inspect closer tonight when I get home and will report back.
If that were me I'd be pulling the whole motor and going through every inch of it turbo'd or not. I will admit I'm jealous you have a turbo 4runner.
@pappy, I would be inclined to disagree with you.
.@pappy, I would be inclined to disagree with you. If @sn22 is only getting ~50psi on cylinder 3, my guess would be a head gasket issue. Although I am a little biased since I have the same problem in my 22rte.
The "nice" thing is that you can use a late-model 22re head on a 22rte. You get a slight compression ratio increase and they are easier/cheaper to source.
Good luck on your turbo journey!
My assessment of the history of this 4Runner is that it was overheated because of poor cooling system maintenance. When the PO dove in to fix it he got in to a certain point and then said F this and threw it back together to sell it.
If you're gonna do all that, just pull the dang motor out. So much easier to work on it when it's on a stand
If you're gonna do all that, just pull the dang motor out. So much easier to work on it when it's on a stand, especially a turbo.
See if I can find a CT26 Turbo and a header and have 3" exhaust put on it and do the necessary fuel management adjustments to keep everything happy. I will check the block gasket surface and see if its smooth enough for a MLS head gasket and get a stud kit. Keep the boost below 15-20lbs and I think it'll be happy and run out pretty good.
