It had been sitting in a garage for the last 20 years. It had a 350 from the early 70’s which was pulled. Who ever installed the 350
Thanks
I am over in the Tri-Cities probably a little to far away. Do you know anyone over this way that would be knowledgeable?Where in WA are you? I’m in WA and if you were close enough I could come look it over with you and try to give you some thoughts on what’s there and what could be done.
I had a stock 72 FJ40 bout 30 years ago really liked it. This one has the original motor mounts and all parts are there except needs a new engine wiring harness. The 350 came with it and is a mid 70's guy said it was running fine when pulled. Do you know if a a Chevy/GMC 250 engine will fit the LC motor mounts and bolt up okay without adapters? It is a 77 truck 250 the owner had rebuilt and up graded had less then 10k on motor pulled for v8 swap has a Clifford 6=8 kit . The guy who has it wants $2,500 for it.My suggestion would be to find someone local who has a similar year and ask to drive it before doing anything. There are a lot of people around who love the look of the classic FJ40 but decide it not the something they want to drive. Few years back missed out on a 77 FJ40. Found out later it was sold pretty wuick. Watching mud seen the same thing happen many times. I'm either too old or dumb to realize how primitive there are.
Second if decide you go further would explore how much was remove or cut up to install the V8. There were some old conversions done using the original motor mounts. If there are still there getting a 2F back in there will be a lot easier and cheaper. If a home conversion for the V8 want to start from scratch installing another one. That not as straightforward as a 2F.
Everything is there and the overall truck is in very decent shape except for some rust in the normal places mainly the lower rear quarter panels. If I decide to sell would be in the $12 to $15k range.@Zuma Did you buy it? Sorry I missed the part you do own it, so how much are you thinking?
Besides the engine what else is going on?
Yes it is a chevy/GM 250 straight 6 and already has a Clifford 6=8 kit on it. Do you know if it wil fit the stock motor mounts and bolt up to a FJ40?A chev/gm 250 is a straight 6 cyldr engine, and is not a v8. Clifford was a company that offered 6 cyldr upgrades for more power.
