86 2F in to a 78 40 series
JDNs78FJ40
Draper Utah
Possibly going to pickup a 2f from a 60 series with a fresh rebuild on it, 10k miles+/- on the rebuild. Any issues transplanting it in to my 78 40 series? Not sure if the 86 has an oil cooler and my 78 does not. Even though it’s quite the drive I’m considering it since the time money and effort tracking down the parts to rebuild mine seems like a pain. Thanks for any input.
It'll work. I have a '85 2F in my '77 FJ40. As I recall I needed to use the FJ40 front motor mounts. The '86 will have an oil cooler but the coolant lines should mate up the 40 lines ok.
I put an 87 2F in mine. Kept the oil cooler on JimC’s recommendation. Blocks are the same, just move over assessories. Easy and good swap. I put the coil where my 1974 coil was. The alternator switched sides and the voltage regulator went away. Coolerman built me a plug and play harness for that. The pax side FJ60 mount won’t work. Just use the 40 one as mentioned above.
I was hoping for higher compression numbers on this engine. He did mention that was on a cold engine but considering how far I have to drive I think I should pass.
Compression figures are as follows:
Cyl. Psi.
1 120
2 110
3 110
4 120
5 120
6 120
There does seem to be some internal noise when running, characteristic of a worn skirt or wrist pin on a piston.
