Nav to Non-Nav Conversion Walkthrough (2 Viewers)
DIY Non-Nav Harness Extension and files for the circuit board and 3D print cover are posted on GXOR FB. I'll try to post it on here soon, but didn't know how to attach the .zip and 3D print files on here or if that was allowed.
Added a link in the DIY writeup for the print circuit board and 3d print cover files
Here's the link to the DIY Non-Nav Harness Extension, I didn't want to hijack this thread anymore than I already had.
DIY Non-Nav Harness Extension - https://forum.ih8mud.com/threads/diy-non-nav-harness-extension.1355429/
Here's how I did the same thing. Ultimately everything worked but it was touch and go for a bit with the ac compressor when I initially used the wrong year hvac controller.
With the help of MANY people (from IH8MUD to GXOR to google), I'm happy to report that I've successfully converted my GX470 from the stock/OEM navigation/stereo to an android head-unit with non-navigation climate controls. I'll document my experience here...
*** FOR NOW, THIS THREAD WILL BE A WORK-IN-PROGRESS***
(It'll probably take me a few days to a few weeks to properly document everything here, but I'll try my best...)
Huge thanks to Adonis (@JSsinodA ) for all the help! For those who care, I'm not that handy... I've never installed a car stereo before, and the extent of my car know-how is fairly basic (I can do basic suspension, oil changes, tire rotations, etc.)... POINT BEING, if I can do this, pretty much anyone can... JUST MAKE SURE TO GIVE YOURSELF ADEQUATE TIME AND DON'T BE IN A RUSH! I completed this project over a three-week period, most of which my GX dash was completely ripped apart... it looked like I was driving a stolen car.
Final product:
Steps that I will cover:
  1. Purchase Parts!
    1. OEM climate controls / brackets / bezel ~$200
    2. Headunit - AliExpress Android 8.1
    3. Backup Camera
    4. Antenna Y-adapter and micro-adapter
    5. USB inputs
  2. Test your OEM climate controls once you receive them from salvage yard - Need to make sure they work!
  3. Back-up camera - Run the lines
  4. Install Non-nav climate controls
    1. Trim climate controls so that Android head-unit will fit
    2. Extend the wires (7 required... 1 additional to make life easier)
    3. Illumination fix - Splice wires to ashtray light
  5. Install new Android head-unit
Anyhow... I'll start including details when I have time!
STEP 1 - PURCHASE PARTS!
1. OEM Non-nav climate controls, brackets and bezel
- Sourcing these parts can be challenging... I'm in Southern CA and with the help of others, found them at a scrap yard in Texas. It cost me $225 to get the climate controls, bezel and brackets removed from the donor car and shipped to my doorstep.
Below are the OEM Lexus part numbers for the non-nav climate controls, listed by production year... (I lifted this directly from @theferg post below... he is also a great resource for this conversion!). It is essential that you get the right part number, otherwise the controls won't work properly.
88650-60770 (11/2002 - 10/2004) (folks have also seen an 88650-60B50 for these years as well)
88650-60771 (11/2004 - 07/2005)
88650-60772 (08/2005 - 12/2005)
88650-60773 (01/2006 - 07/2009)
You can find your production year in the drivers side door jam label:
(Also note that those with production dates on the switch-over months--ending/beginning months--seem to kind of have a crap-shoot of a time figuring out which one is the actual one since some sites list the production dates slightly differently. This list I posted has been spot for the good handfuls that have done this on GXOR fb page.)
When you finally get the climate controls, you can find the part number here:
2. Aftermarket head-unit - The common choice is the 9" Android head unit from AliExpress (China). You should get the 8 Core 2G 32G CANBUS version... it ran me $250 shipped, and arrived in about a week or two.
Theoretically, once you do the climate control conversion, you should also be able to choose a double din HU from a more common manufacturer (i.e., Alpine, Kenwood, etc.)... I believe that Crutchfield sells new bezels and mounting hardware for non-nav versions of the GX470. But personally, at $250, the above Android HU is worth trying out... that's what I went with, and so far so good.
3. Backup Camera - I used the following camera, but honestly I'm not that happy with it... It's just not that clear, and comes in a little grainy and streaky (if that makes sense). But ultimately, it works.
Amazon product ASIN B07HNRYHZ6
Amazon product ASIN B01I97Y49IAmazon.com: SCOSCHE MDAB 1988-05 GM Micro/Delco Antenna Adapter; Tip only: Car Electronics
5. USB inputs
I have a Prado 120 from 2008 so which unit do I need and is there a place I can buy the wiring harness 😎 I am no Sparkie
Interesting mod to install aftermarket hu into a factory nav setup. Still requires a bit of work, but you don't need to buy the non-nav components. And doesn't look as clean. But as those other parts get harder to find, this is an alternative option.
"Feb 14, 2025
Yes! It is possible to install a modern aftermarket radio with wireless Android Auto and Apple Car play in your GX470 with navigation and the Mark Levinson sound system. This was possible thanks to the Beat-Sonic amp interface adapter. MVA-81. I installed a single DIN 10 inch head unit that swivels. The steering wheel controls work too."
When was the last time you emailed him? I tried last night, delivery failed.
Sorry, my contact with him was a few years ago. It was not super fast, but relatively steady and I got the harness in a few months. There is another nav thread here where someone shows all the necessary steps, what to buy, etc. Hopefully someone will start making these, the conversion really is an amazing upgrade.
Hello to all and to whom ever can help. Thank in advance. Ive been doing my research regarding this conversion and decided to pull the trigger and buy the parts needed to complete this conversion. I have 2009 GX 470. I am planning to pull the connectors and extend on the 7 to 8 wires route. since logistically make senses to me, that to build my one Harness. I am not a wiring guru and my question is, what size gauge wire should I use for he the extension? and do I still need to make the pigtail to the cigarette lighter for illumination? I would like feed back from anyone who has gone this route.
20 to 24 AWG wire should work, and you would need to make the pigtail to the cigarette lighter for the controls to illuminate with the headlights. Congrats on finding the unobtanium '09 non-nav controls. Good luck with the swap, just take your time and test the hvac controls before you button everything up.
Has anyone tried the EDM or JDM versions of this? Only thing I can think would be different would be the temp display in Celsius. I tried searching the part numbers in this forum to no hits.
two part numbers:
88650-60611
88650-60612
