It’s worth the effort to fix. I’ll bet an old exhaust leak had something to do with the initial problem.
This thread was the key to me finding my issue! So thankful for your tenacity in finding your issue, as well as PADDOs comment about the muffler leak. I had a muffler hole that was left a while (ostensibly because it sounded throaty). My theory is that sitting idling with a muffler hole/exhaust leak lets the hot exhaust wreak havoc on the wiring under our rigs. Hot air rises and finds the worst possible place to escape (top of frame rail), and is the destroyer of wires and BG1. Here's a pic of my C1721 short, directly above the frame rail, right next to the middle muffler where I had the hole. I'd call that a short, wouldn't you? (side note: amazing design that anything in the suspension ECU works at all with a short like this connected to it).
It feels like a Public Service Announcement for AHC folks "if you have a muffler leak, FIX IT before it's the size of a softball and melts your AHC wires down)
Theophilus, have you been able to get to the burnt cabeling and do the splicing even without cutting the fender like goldigital did? Seems as indicated today on Techstream, my AHC besides having too high pressures front and rear has the C1721/C1723 codes too after I was having a split open muffler.
Did you use 18 gauge to splice?Fixed! C1721 is finally gone! Here's another shot of the fried wire, and a link to the silicon high temp wires I used to splice the harness.
https://www.amazon.com/BNTECHGO-Sil...coding=UTF8&psc=1&refRID=JZ47F6B6DXQ6H72HEBPM
