Really like the intake manifold, so much more space efficient than mine. Running a setup like that and you can still use the factory location for a second battery, something that my setup doesn't do very well. I may look into something like that.
@Realst8 what wastegate did you go with. I got the CX manifold and a BW turbo but not sure what wastegate to go with that will work with the CX manifold that is still quality. I did not want to use theirs.
Nice set up, I have a off topic question how difficult was it to move your e-brake to the other side of console? I've thought about it and or a E-stopp. I real would like a descent arm rest that doesn't look like a$$. Thx
FWIW, I didn’t find it necessary to move the parking brake. Very comfortable for armrest.Nice set up, I have a off topic question how difficult was it to move your e-brake to the other side of console? I've thought about it and or a E-stopp. I real would like a descent arm rest that doesn't look like a$$. Thx
Do you have yours reg'ed outside of Riverside county, or in a less restrictive zip code? I have a hell of a time getting my FJ60 smog'ed in Riverside.Not all counties in Ca require smog checks on renewals https://www.dmv.ca.gov/portal/dmv/detail/vr/smogfaq.
Nice work, bet its fun to drive!
Nope, StockLess restrictive zip. Is it modified?
@Realst8
Did you start with the complete CK kit?
Are your fender vents powered?
Did you upgrade your exhaust?
How much are you into the set up?
I ordered the kit with the manifold, wastegate and downpipe, no intercooler and no turbo then purchased a t67 turbo from cx racing. I pieced together other misc. Fittings hose etc. Their kit is not complete.
The fender vents are not powered.
Exhaust is a bosal muffler and no resonator.
I'm in it about $2,700 including an innovate wideband
It would be super cool if you took the time to do a detailed break down on how you did it so clean for $2700.
Im sure myself and many would be interested.
3" Cast Aluminum 90 Degree Elbow Pipe Tube Turbo intercooler Polished | EB300-90-CAST-P | 1 | $27.30 | $27.30 | |
3" Cast Aluminium Elbow U 180 Deg for Intercooler Turbo Pipe Polish | EB300-U-CAST-P | 1 | $42.00 | $42.00 | |
2" T-bolt clamp Supercharger Turbo Intercooler exhaust | CLM200-T | 1 | $2.10 | $2.10 | |
2.5" T-bolt clamp Supercharger Turbo Intercooler exhaust | CLM250-T | 2 | $2.36 | $4.73 | |
3" T-bolt clamp Supercharger Turbo Intercooler exhaust | CLM300-T | 7 | $2.47 | $17.27 | |
3.25" T-bolt clamp Supercharger Turbo Intercooler exhaust | CLM325-T | 1 | $3.41 | $3.41 | |
2.5" OD 3" Long Aluminum Joiner Pipe for Intecooler Turbo | PIP250-S-3 | 1 | $15.75 | $15.75 | |
Black Silicon Hose 3" Straight For Turbo Intercooler Pipe 13" Long | SH300-4BK-345 | 1 | $29.40 | $29.40 | |
Elbow Black Silicon Hose 3" 90 Degree 2.5" Long For Intercooler Pipe | SH300-3BK-90-65 | 1 | $17.85 | $17.85 | |
2.5" - 2" 90 Degree Black Silicon Hose Reducer Elbow For Intercooler Pipe, 85mm Long | SH250R200-4BK-90-85 | 1 | $17.85 | $17.85 | |
Black Silicon Hose 3"-2.5" Inch 90 Degree Coupler For Intercooler Pipe 85mm Long | SH300R250-4BK-90-85 | 1 | $17.85 | $17.85 | |
3.25" - 3" Black Straight Silicon Hose Reducer Coupler Pipe 3" Long | SH325R300-3BK-76 | 1 | $8.40 | $8.40 | |
Copper Fitting NPT 1/8 to AN-4 Male Thread for Turbo Engine | OF-AN4-NPT18 | 1 | $8.40 | $8.40 |
T4 T67 Turbo Charger Turbocharger .81AR P Trim 67mm Wheel 500+ HP | TRB-T67-P81 | 1 | $319.00 | $319.00 | |
T4 T70 Turbo Kit Manifold Downpipe For Land Cruiser J80 1FZFE 1FZ-FE 1FZ - Turbo & Wastegate Options: Without Turbo | TRB-KIT-1FZFE-T70-NO-IC | 1 | $930.00 | $930.00 |
