Nearing the end of Phase 1
So we are getting close, lots of work done in the last few weeks. In short, it's standing on its own legs. Front brakes rebuilt, steering is all buttoned up, new power steering pump is in, gear oil is in, chassis lubed, changed the engine oil, etc, etc, etc.
Here it is, completely off of jack stands for the first time in a couple months:
I trial fit the drive shafts. The rear is in great shape, and well within tolerances. The front on the other hand, is a wee bit short:
So, I sent the front shaft out for some lengthening, new joints and balancing. While the shop was at it, I elected to send out the rear as well, to ensure it's all balanced proper.
While waiting on the shafts, I decided to do a little grill work:
Obviously my grill was in pretty bad shape. I would not have elected for such major surgery on a halfway decent grill. Once I had the center section out and the surround cleaned up to my liking, it was time to create a template:
Transfer the template to the new grill material:
Then; cut, paint and install:
Once this thing is out of the real daylight, getting better pictures should be a little easier.
Then, the driveshafts came back:
So the shafts are in, the grill is complete. What's left???
Well, as I mentioned before, I do need some new brake tubes. These are the tubes, on both axles, that go from the chassis/axle flex line, out to the axle ends. On the rear axle, this consists of 2 lines; from the bulkhead out to the wheel cylinders. On the front axle, this is 4 total lines; from the bulkhead out to the knuckle flex lines and from the outboard of the same flex lines out to the calipers themselves. Unfortunately, mine are all pinched, bent, tweaked, rusty, leaky and generally e'ffed up.
I tried $OR for these parts, with no luck. I talked to CruiserDan to find out that these lines are truly NLA. So, I found a spot online and ordered the line in bulk, as well as the fittings.
This coming weekend will be spent bending up all new lines and installing and bleeding brakes (and bleeding the clutch as well). After that? Ill be chasing an alignment.
Then, on to phase 2: Body, Paint and complete the interior.
