My little project
My little project - HZJ79
Hi guys, I have been working on my little project over the last few months, it is close to being done but thought I would share it as it stands to date.
This is what I have done to it so far:
New doors and front clip (front clip POR 15'd)
Factory Toyota white paint, Top of the line paint (can't remember type)
New grille
Tons of interior parts
A/C system rebuild
New rockers
Every steering component changed, main shaft, TRE, relay rod and ends, etc etc.
Frame sandblast, POR 15 entire frame
OME shocks and steering Damper
OME 2 inch lift, Coil front, 56 inch rear springs
Complete new rear end
Toyota 100 series 32 spline rear e-locker 4.30 gears
Lonspline axle shaft
Complete front end rebuild including massive new type toyota discs and calipers
2 X Tom Woods custom driveshafts
4 new toyota 5 bolt rims
4 new 33.4 inch BFG mud's
Aisin winch
Rock sliders
Custom front bumper
3 inch stainless muffler system
Safari Snorkel
Donaldson Cyclonic intake
free wheeling hubs
2X short type birfs
front and rear diff armour
Headlights
wiring
Gas tank repair and recoated with POR 15
Timing belt, tensioner, pulley
waterpump
connecting rod bearings
mechanical oil pressure guage
engine painted with POR 15 high heat enamel
Most nuts and bolts replaced with stainless
Fatmat sound dampner
I have forgotten tons of stuff but will add as I think of it.
Just about every part that come off it was replaced with new toyota parts from Japan, Australia, Toyota, G and S, Japan 4X4 etc etc.
This project has cost me so much money I don't even want to add it up.
I still have to replace the front axle housing, the entire wiring harness, aluminum trayback and I am going to swap a JDM engine/tranny transfer in it just to have a fresh powerplant for a mapped turbo. I expect I will have about 40K into this when it is done.
Engine runs great, no oil burning, no real smoke to speak of, plenty of power, it just sounds more like a diesel than a 1HZ usually does - probably because it has 4200 hours on it.
My plans are to build up another 79 in a year or 2 that I can take to an Outback Challenge. The truck I just completed was good to get to know the truck.
Comments are always welcome.
welcome to the club "god damn that adds up fast"...
looking real nice...
congrates.
when i finally get down there we will have to meet up for a putz and Tims...
Wow this is looking good:D That tray you have looks ok too but I would lift it a few inches just for looks;)
A canvas type canopy would really set it off.
I see you have a blocked filter sensor,is that a Canadian mine spec?
Blocked filter sensor - on the air filter? If that is what you are talking about the sensor is that white plastic gizmo on the top of the air canister.
Or is you are referring to the white plastic filter at teh firewall - that is a filter for the front wet brakes. I removed them as well and had to buy all the front end parts from the knuckle bearings to the hubs - very costly.
Blocked filter sensor - on the air filter ? Yes thats the one:D I dont recall seeing it much on cruisers outside of oz.
With all that work it drive like a new truck. They are one of the best vehicles for rebuilds.
Really nice job, and good rebuild. It really warms my heart to see a 75 cruiser restored to better than original.
Cheers
The photos don't do this thing justice, it's a really nice ute. The paint is gorgeous, it's super clean, and it's a blast to drive. I am very very impressed with this truck.
The big project would be a rally/challenge type truck, so it could be ran in the Outback Challenge or something similar. High speed winch, cage, shorten the frame a bit, beef up the front end, bigger lift, better shocks, tweeked turbo diesel, Dual GPS, lockers, lots of custom work etc etc. I'd need a partner for that type of project though = a pricy undertaking just for a week and a half of whiteknuckling it.
This type of thing has always been a dream of mine ever since a friend of mine ran some cruisers in a few events in borneo and australia back in the late 80's. Races don't really appeal to me as they aren't technical enough, these outback challenege type events are really appealing though - more skill involved in my opinion.
Regards,
Nice work Louis,
Looks awsome and rugged. Beats any post 2000 truck I've ever seen.
Cheers,
Deny
Thanks Deny. I'd have to say that this truck is more comfy than the 8X series I've owned, there is tons more leg room, I have to actually move the seat up to make good contact with the pedals (I'm 6'1"), I can't get enough room in an eighty or other 7X series it seems.
Also, the breaks on this truck are huge, the rotors min thickness is 30mm compared to the 19mm on the 80 series, the rotor and caliper is similar to the new tundra brakes in my estimation - tons of breaking power in such a little truck - the rear drums are huge as well.
Toyota also changed the rear full floater rear hub assembly size as well as the rear axle shaft size, both are noticeably larger, hence the 32 spline rear end and the 5 lug pattern.
