I did a frame-off restoration and upgraded a bunch of parts along the way only to end up with the truck handling very sketchily. These are all new tie rod ends, shackles, springs, bushings and the axle/birfs/bearings all new. Toe in is 1/4" on 31" wheels. 4degree caster wedge. New Bilstein 5120 and stabilizer.
Here's what I am experiencing;
1. Truck wanders all over the road
2. Bumpsteer in the extreme
3. Exaggerated brake dive
At first I thought it was the drag arm hitting the front shock but I relocated/adjusted the steering box inboard and they no longer contact. The front springs are new from Alcan. They look a bit longer/the front shackles are slanted more that I member seeing on the truck before.
The front steering arm drops a long way down, I seem to recall it being preferable to get that steering arm from the center arm to the right knuckle as close to horizontal as possible.
I am thinking...
...do I need a drop arm on the steering center or a lift arm on the right drivers' knuckle? Revalve the shocks more stiffly? Shorter or more curved front springs?
ITs killing me to to be able to drive this thing...but it is absolutely dangerous right now..
I am thinking...
