How much should I expect a shop to charge for labor to replace both?
I like your thinking. The thinking in the Porsche 928 world is "Why pay someone else to LEARN how to fix your car?"That will be a heavy $$$ bill. Don't go there. You should do this yourself, no matter how much money you have. The reason is, no one will do it well, other than you. Get comfortable with the Toyota axle and knuckle. Then YOU can tackle any job your Land Cruiser will ever need. Buying new Birfields will be expensive. Spend your $$ on the good parts, not the labor you can do yourself.
I love it!Doing your birfs is a right of passage. It's daunting if you've never done it before. It'll probably take you four times longer than you think. It's a filthy disaster of a mess. Your doctor will ask you months after the axle service where the black moly grease deep in your ear canals came from. But - and here's the important part - after you've done it, you'll feel like you can tackle anything on your cruiser. Better yet, when you need to do it again, you'll knock it out in a couple hours including the beer breaks. You've totally got this.
There are a couple of how to videos out there, including these:
Buy the seals, bearings, new cone washers, Moly grease, and anything else you want to replace beforehand. You don't need to buy steering tools, such as a TRE puller; you can "borrow" them from VatoZone (for a refundable deposit). You will need a ball peen hammer, punches (steel and brass), shop rags, a couple of buckets, a length of PVC pipe (for the driveline snap ring), etc (the list is in the FSM). I'd say it's a weekend job for most people, at most. The only possible delay would be finding you need new cages, then you're out while you wait for delivery.
IMO, you can do this yourself, unless this is your DD and you have no backup, and know a shop which has all the parts you could possibly need before you take it in. Then, you're out about a day, if you're lucky.
I'm more unclear on this than I probably should be. I think I may be having symptoms my birfields are going out, can't see anything definitive. The only time I hear clicking is when the t-case is locked and I'm turning in drive. No clicking in when it's not locked, and not in reverse. I had not heard it until recently as the t-case would not lock until I removed the t-case loopback wire in the dash and threw it in 4 low and it locked. Now it locks with the loopback. Is this birfields? Clicking is not loud, almost didn't hear it at first.
