Wanted to design something a bit more modern and reliable for my '69 FJ40 rear hatch lifts. Fabricated my own mounts designed to utilize the original mounting holes. Searched the net and found an enormous selection of lift supports at Lift Supports Systems | Hood | Window | Trunk | Hatch | Auto Parts By Lou. The guy woking there, Lou, really helped me out sending some back in forth since I had no idea what I needed. Needed a compressed length under 13". I found 80lb way to heavy - settled on 52lbs.
This is what I ended up with:
Ball Stud 10mm 4 pack Code H91591B-4
Lift Supports 52lb Code 10574
Cost around $60
Cost around $60
