I swapped a 1hz motor into a fz80.
Unfortunately the 1hz motor came from a 70 series truck with no tach, so the injeccion pump didn't have a tach signal.
What i did is take the pickup coil out of the distribuitor and mounted it over the A/C tensioner pulley. and epoxied 1 very small super magnet to the 3 inch pulley.
I left the coil and spark box in place and plugged in the "distribuitor" which is just the pickup coil.
I hooked up a sparkplug to the coil plug and grounded it.
The sparkbox still thinks it has a distribuitor hooked up. and every time the maget spins by the pickup , the coil sparks and the tach works and the A/C works.
It is pretty acurrate as the pulley on the damper is 9 inches in diameter and the idler pulley i used is 3 inches so the ratio is 3 ti 1. so every time the motor spins 1 rev, the coil sparks 3 times.
Being a 6 cilinder engine the ratio es pretty much dead on. At idle my tach reads 800 rpm and it redlines at 4200 rpm.
I'll try to take a picture and post it.
Hope this helps
Hope this helps
