My 1980 Fj40 Build by Ferportu
here are some photos when I bought my fj40 :)
255/85r16 tires
PTO winch ramsey
new tires swamper Q78-16 on split wheels
turn signals were changed from 70 series style back to factory 40 style :)
Nice 40. What soft top are you running?
Que tipo de capota tiene en la troca? Se ve muy bien en su 40.
Ed
you know if those 16" non-split rims are that common in Venezuela...you can make some money selling them...there are ALOT of guys here in the USA that would love them!!!
that is if they are oem toyota...are they?
do you see any stampings on them?
que mas...saludos pana,oye que suspension tienes en tu 40 ? 4 '' ? ese dogo argentino esta nice..saludos dsd Puerto Rico....
thanks, tiene leaf spring OME 3"de 60, y se corrieron los anclajes un poco,
Full Floating
In Venezuela, the FJ40 came stock with 3.73 gears and semi-floating rear axles.
I purchased a Full Floating (FF) rear axle with drum brakes from a 2007 FZJ71 and modified it to be installed in the rear of my FJ40. There was a win-win situation after doing this:
1.- I would gain the FF axle
2.- The new axle comes stock with 4.10 gears
The FZJ71 came with the 5 bolt pattern on the wheel hub. The hubs were machined to accept the 6 bolt pattern standard to older Land Cruisers. The spring perches were also moved to match the width of the FJ40 mounts.
Since the 71 axle is a little wider than the 40 axle, I added a small wheel spacer in the front to match the track front and rear.
At the same time, I replaced the gear ratio on the front 3rd member to 4.10 (same as the rear axle). Also, I took this opportunity to install ARB air lockers front and rear :cool:.
The drive-shafts that came with the truck were Venezuelan-made shafts and I purchased a set of OEM Genuine Toyota drive-shafts. These were installed at the same time as the gears/lockers.
Some photos of the process:
