SUMMIT CRUISERS
I'll be working on a supercharged 80 series with the ring fan shortly due to the owner complaining of continuous running hot on hot days (100 deg ambient) and higher elevation cruising. His scangauge is reporting temps hovering around 210 and higher.
It looks like I'll need to drain and refill with 20,000 CST and get a 3FE fan. Anything else?
He lives in NM as well.
Thanks.
If it's running continuously hot I'd be looking at the radiator as well.I'll be working on a supercharged 80 series with the ring fan shortly due to the owner complaining of continuous running hot on hot days (100 deg ambient) and higher elevation cruising. His scangauge is reporting temps hovering around 210 and higher.
Thanks.
Howdy! Just a quick word of warning. The 3FE fan sit nearly 1/2" closer to the fan clutch, so if you have fabbed up a custom wrench to fit on the S/C tensioner pulley, it will not fit any more. I had to do a lot more cut/grind to make mine fit. Can be done, but it took me a while to figure out why it was easy to remove the S/C belt, but no way was it going back on!! JohnI'll be working on a supercharged 80 series with the ring fan shortly due to the owner complaining of continuous running hot on hot days (100 deg ambient) and higher elevation cruising. His scangauge is reporting temps hovering around 210 and higher.
Thanks.
At what speed does the fan not matter? I always thought about 35 mph. So if your running hot at highway speeds, I would look at other parts of the system.
So I have a 97 cruiser here in Vegas with 100k miles. I've replaced all the hoses and done the flush. So far the AC works great, no issues. We are getting ready to do a full tune up, including a new blue hub fan clutch. Should I just start out with the oil it comes with and see how things work before bumping up to a heavier oil? Being in Vegas, and seeing how it is 113 out, good AC and cooling performance is at the top of my list!
If it were me, I would calibrate the fan and put in the 10k fluid from the start. There have been enough blue fan clutches that hacvent worked well out of box,why not spend 30 minutes at the outset and have it right?
So is everyone following landtanks step by step directions he did in this post: https://forum.ih8mud.com/80-series-tech/102633-blue-fan-clutch-mod.html
Or are you just draining and filling in with the heavier oil?
