Heads disassembled and prepping for valve lapping. All valve springs checked out okay. Valves don’t look too bad but will get cleaned up and also checked. I could definitely see spots on the cylinder 3 valves where they did not have a good seal so fingers crossed they can be fixed with some lapping.
Fun fact, the intake and exhaust valve stem seals all look the same (besides the stem opening size difference). I was expecting the exhaust to have an extra flange along the bottom. I tested out reinstalling one of the removed ones and they push on very simply by hand. The SST pushes on the ridge but I think using a fingertip gently will be okay.
In other news, I found some old FIPG wedged into the heat exchanger fins on the coolant inlet side of the oil cooler assembly. I removed what I could (see arrows), but I can see more between the fins so a replacement will be needed. I believe this occurred because a previous tech used both too much FIPG and also did not let it cure enough before starting the vehicle. If it was still flowable it would travel through the system and get wedged in the heat exchanger fins like I found since it basically acts as a giant filter. @2001LC or anyone else that works on these a lot, have you seen anything like this before?
