I meant automotive shocks.
sorry if not clear. i got your point. if nitrogen then a bike shop will not help.
I finally got them on last night. I had to cut both of the rears off. After 14 yrs and 165k miles, things tend to become hard to unbolt...
I think the ride is much more refined. They are certainly not as cushy as I led on. They seem to react to small bumps similar to OEM and soak up the larger ones much much much better. Cornering seems about the same if not flatter than previously, but that could be because my rear shocks were essentially toast.
It was certainly easier to compress the OEM shocks with my body weight than the Fox's
With dips in the road, you get about 3 cycles before coming back level. A decent down, a bit of an up and then back level. It seems to return to level in less cycles than OEM and smoother too. The transitions between compression and rebound are really smooth. I certainly don't feel like I'm driving a boat any more than I did with OEM. I am very happy with them. I will report back after this weekend, I will have about 10hrs of highway time and some mild offroading.
I put a bunch of miles on my new Fox's this weekend. I think overall they are great.
Pros:
-soak up big bumps
-weight transition in corners is much smoother
-better ride on rough roads
-95% of highway travel is sooooo much more comfortable
Cons
-that other 5%... They can be a tad floaty. I think the rebound isn't quit firm enough. Traveling at highway speeds, if there are some rolls in the road you tend to get shot upward more than I would like.
Personally, I think the compression could be a bit softer and rebound a bit firmer.
Overall I am happy. 99% of the time, these feel like a significant improvement over the OEM shocks.
Interesting opinions. I'm now running the 2.5 RR Radflos (with TC UCAs). They seem great so far. Maybe a little on the stiff side on the small stuff (more road chatter than before) but when you take a big hit they just swallow it up. I have this one RR crossing that was made very poorly and most cars slow to 20-25 (road is 45 posted). I can do it at 55 with absolute zero discomfort of perceived loss of contact. The only thing I get is a touch of tire rub on DS front fender liner, but that's the fault of the wheel spacers, not the shocks. The first time I hit it I was blown away and kept increasing my speed to the max safe for the road. I have my first week long expo on them next week so I'll report back. These are the new longer travel Radflos so none of the click probs others have posted.
The only necessary 'fix' at this point is to get some Timbren bump stops up front. The 1" JT spacers and TC UCA's cause the 35's to hit the fender liner on big compressions. Not into the metal, just noisy plastic rubbing.
Based on my experience, the Timbren bump stops are unlikely to eliminate the contact you describe above. I find that the Timbren's do a great job of eliminating the harshness of bottoming out the up-wards travel, however they are relatively soft and as a result don't really "limit" the upwards travel very well...
I'm running a 0.5" body lift, and the timbrens, and I still have my 35's (these days 34's) making contact much like you describe above (I'm running AHC still, so that's different, but when it comes to the "limiting" ability of the Timbren stops, I'm not sure that this matters much.)
Just and FYI -- your mileage may vary.
Good input. So, can we add spacers to move them down?
^^ agree with this.I put a bunch of miles on my new Fox's this weekend. I think overall they are great.
Pros:
-soak up big bumps
Cons
Thanks Nick for the update.
I have a heavy truck...rear aux tank 40+ gals and slee bumper. I am going to get rid of the 863s for Slee Heavys and I would love to ditch the OME shocks. I have never liked them on any truck I have owned way to stiff.
OK, now you've got me wondering...I am on the fence with these right now. I am debating on pulling them off, however at the same time I am enjoying them. It's a love/hate relationship. However I can't say too many good things other than when I am on a perfectly flat road, at a stop light, or sitting in the truck when it's not running.
I did a hair over 1,600 miles this past week with them, the first 500 miles I was completely empty. The ride was compliant through the construction zones on I-75 South and rode very, very nice, though a bit bouncy. On the smooth wide open pavement on the Florida Turnpike they were incredible. I had cruise control set at 80MPH (short spring to find out if the 100 is limited to 109MPH...mine apparently is not)for most of the trip and the dips and rises in the road the Fox Shocks were great....but this is were the good news ends. I stopped and loaded up the rear of the 100 with roughly ~450LBS of fireworks and got back on the highway, I could not cruise any where near my previous speed. The dips and rises became mountains for the rear end. It was constantly bobbing up and down and if I had to take a corner or get off the whole truck would just bounce uncontrollably. If you hit a dip or rise in the road while going around a corner it's like the truck wants to bounce out from under you.
When I drove through Miami on I-95 South, the roads are full of horrible patch jobs, large (I mean huge) dips and traffic is absolutely nuts. If you aren't driving like a nut job, you will be hit. The quick lane changes, sudden stops, and 85MPH between a concrete divide and a 18-Wheeler was horrifying. It was like the rear of the truck was on its own agenda, it just did NOT want to settle down.
I wish I could say more good things about the Fox shocks. I thought it was my nose heavy 100 that was causing this issue. It seems the more weight I add in the back only makes it worse. Maybe I did get a defective set of shocks. I can't possibly imagine anybody wanting a truck that already is top heavy and over-weight ride so mushy. Everybody that rides in it (even people that know nothing about cars) say it feels a bit loose back there.
In short, I'm not happy with the Fox 2.0's. It's almost like Fox took the shock off a JK and put a different mount on it. It's way to soft, it can't handle the weight, and certainly doesn't belong on a truck like mine. If you have a stock truck, I bet they would be great. I just need a stiffer shock that can handle my driving style (a little faster than most) and the weight of the rig.
