There is abit of info out there on other engines and their potential but I have not really found much on the 13BT. Sooo..... post up your engines perfomance data and what the specs are!
What I am particuarly keen on is how far have people pushed the 13BT and what (if anything) has broken. I have seen a photo of 13BT pistons where the ring lands appear to have flogged out the let go, have not heard anything of the head lifting off the block at high boost or internal engine failures.
Does anyone have info on the standard fuel pump and how much capacity it has?
First up my mates BJ74 ute, it produced 74rwkw on 37'' tyres through a H55F and 4.11 diffs. 3'' exhaust, stock dump pipe, no intercooler and would up max fuel screw and boost (not sure to what levels.
Here is mine, yet to be on the dyno, it will be once I get a new turbo on it, it runs a full 3'' exhaust and dump pipe with single muffler, water to air intercooler (on the small side) 21.5psi boost and I have about 3 turns on the max fuel screw and I have adjust up the "guide bushing" no changes to the boost compensator. To drive on 33'' tyres it is very similar to my dads stock VDJ79 which puts out 430Nm torque, so I must be up around that figure.
I know there are a couple of modded ones around on this site, 14BT pumps etc.
The only other dyno info I have seen is one that dynoed 98rwhp, I am trying to get more info on it.
