Towpack said:If you want to experiment fit a pyro gauge.
Behemoth60 said:I know that anything over about 1000psi can be pretty dangerous in the event of containment failure. But even a large volume of air at just 4PSI can kill you under the right circumstances (like trying to seat the bead on a tractor tire and the tire blows out), but those circumstances are unlikely in a turbo system. I would say that as long as the hood is down and you're behind the firewall, if there was a catastophic failure of the intake manifold, it's unlikely that any of the shrapnel could penetrate the sheet metal and harm your or family in the vehicle. If you were really concerned, you could probably wrap your intake in some sort of balistic blanket like racers do for their clutch plates. Then you can safely run somewhere into the low thousands of psi. Probably no more than about 3,500psi though.
Technikev said:Umm... what?
IMHO it is unlikely that you will blow up your intake. If too much boost, probably just blow off an intercooler piping flex boot or a gasket. Personally I would limit boost to around 20 PSI, but I would increase it incrementally. I believe you would be absolutely safe at 15 PSI. Excessive pressure will probably lead to some unreliability. I think Crushers was running about 14-15 PSI in his turbo'd 75 with a 1HZ. And he had propane to boot.
Remember that its not just boost that gets you power, but fuel also. The higher boost just gets more air in to burn the extra fuel. Get a pyro. 1100 - 1250 PSI max. Have fun.
-kevin
While the boost would be safe, the power you could make with 3,500lbs of boost would be 'killer'. Some of the drag trucks are making 1100hp and 2,500 ft-lbs with just 50psi. The most I've ever heard of is about 160 psi boost in a detroit diesel drag truck. I doubt you can make anything even close to that much boost, so I would say your safety is unaffected by even the most boost you can practically feed into a 1HD-FT.
Peter Straub
adrian00 said:what do you think the max safe boost is for a 1hd-ft with a safari intercooler ???
Behemoth60 said:Adrian00 was asking how much boost is safe. 20psi is a no-brainer. A leaf blower can make 20psi. There's nothing dangerous about that.
The discussion about how much boost you *should* run for engine longevity, power, etc. has been discussed to death, but how much boost could *cause* your death or other bodily harm is an interesting new topic that adrian00 has tabled in his inquiry about safety.
I'm not sure why you guys are yammering on about 15-20 lbs of boost and won't contribute an on-topic post to this guys query.
Peter Straub
crushers said:max SAFE boost was his question...
blownbj said:you Guys are always carrying on about how much boost is safe and what air pressure can do but which one of you has ever popped your cylinder head and could contribute it to overboosting. I don't think there's one!! It sounds like alot of urban folklore I knew a guy who knew a guy who... I would for once like to here a testamonial of someone with a blown 3B that could contribute it to giving it too much fresh air and not overfueling or overrevving.
