Massive coolant leak
Pensacola, FL
Before I start tearing things apart I’ve been trying to pin point the leak but haven’t been able.
My guess is the radiator itself that leaks once it gets to operating temps. Cause I found the leak after months and it only needed a gallon.
Who has the best OEM prices? Or a link to a decent quality replacement?
Most cost effective option is Koyorad radiator from RockAuto, about 180$ , which is identical to the OEM radiator. Only need to transfer the foam pads from your old radiator to the new one. No need to pay 3 times as much for a Toyota branded radiator.
Get a Denso replacement if you can. Just my .02.
Denso radiator is not OEM for the 100's. Koyorad is factory installed on our 100 series.
I hear that. I was able to source one, though some time back.
Ok, I’m going to cancel the denso and order the koyo, thanks.
I don't think you could go wrong with either. :)
