It's not a question of needing more or less fluid.
It is simply that a smaller slave piston has less force, or a larger slave piston makes more force.
The opposite is true for the master bore size.
Going down in wheel cylinder size reduces the amount of braking force for a given pedal force.
Jim,
This is something that I would like to explore a little more with you, and whoever else cares to chime in, for the benefit of all. Disclaimer: my mechanical sense is based solely on inductive and deductive logic. IOW, I have never formally studied this.
Logic tells me that a larger bore master cylinder will move more fluid per inch of pedal travel than a small one. Using exaggeration for emphasis, a 10" bore moving one inch will move more fluid than a 1" bore moving one inch.
Likewise, all things being equal, a smaller bore "slave" as you use the term will respond faster than a larger one. That dynamic is confused in the pre-81 Landcruisers because front drum cylinders only utilize one piston, while the rears use two. So using a 1" front and a nominal 7/8" for the rear, the effective braking is still slower in the rear, because it requires the movement of fluid equivalent to a 1-3/4" single piston. And that is how Toyota's estimation of appropriate bias is achieved.
Under my system of logic, your comment on brake force has to proceed from a deductive universe comprised of disc brake calipers. Where the piston applies DIRECT force to the friction material, i.e. the brake pad, I would completely agree that the "larger slave piston makes more force." But where the piston does not transfer pressure directly, and that pressure is made across a uniformly sized intermediate part, the head of a wheel cylinder piston, to me the size of the piston cannot directly affect the force, only the rate at which the force is applied.
