- Active Height Control (AHC) and Adaptive Variable Suspension (AVS): To ensure a seamless balance between off-road drivability and on-road handling stability, the LX utilizes AHC and AVS – both now standard across the LX lineup. This system provides improved grip, traction, and control as well as a sense of strength and security.
Side note: getting the full-time transfer case with the center diff - it's obviously strong enough - in the Sequoia, and fixing that vehicle's silly 3rd row situation, would finally give the US a great Toyota alternative to the GM twins...Super interesting. Everything from the parts bin. I'm not sure the sum of all the parts is what will sell super well in the USA market, but in a global market I'm sure it'll do well. Put that package in a full size SUV and it would print money in the USA market.
I was pretty sure the reason we never saw the hybrid plus awd was the transfer case strength, but it seems pretty obvious that it's able to handle it or they've re-designed it to work with the full hybrid power. So, why the hell isn't it available in the Tundra and Sequoia?? Huge miss from Toyota.Side note: getting the full-time transfer case with the center diff - it's obviously strong enough - in the Sequoia, and fixing that vehicle's silly 3rd row situation, would finally give the US a great Toyota alternative to the GM twins...
They could just have a button that doesn't do anything and I don't think anyone would ever find out. I'd bet less than 10% of the first owners will ever even try to engage 4lo. I think the number was under 5% for the GM full size suvs and was part of the decision to drop the low range from most trims. But also - does it really need low range with electric torque modulation and highway touring tires? The way it'll come configured from the factory would probably never have a scenario where you'd need low range gearing.Them explaining the front lockers should be equally as fun.
Oh no. They will build a marketing campaign around it with influencers pushing it to effortlessly drive up a hill on a cloudy day while insiders preach how all that plastic is actually a good thingThey could just have a button that doesn't do anything and I don't think anyone would ever find out. I'd bet less than 10% of the first owners will ever even try to engage 4lo. I think the number was under 5% for the GM full size suvs and was part of the decision to drop the low range from most trims. But also - does it really need low range with electric torque modulation and highway touring tires? The way it'll come configured from the factory would probably never have a scenario where you'd need low range gearing.
Whelp, sticking with my base 2022. AHC is now standard for the LX700h across all lines. I've plans for suspension mods, and AHC just makes for a mess.
Maybe I'll get my wife a three row overtrail Lx700hbest of both worlds.
If the LX6 had a tailgate, it would already be in my driveway.RE AHC. Have you seen all the goodness of AHC on the 200-series? IMO, makes the vehicle and I would never own a "Land Cruiser" without it.
With this announcement, the 300-series is growing on me. Still hate that it doesn't have a tailgate.
Crazy that they'd still only have 26 gallons. The new patrol has 39 gallons in the std tank. I'm glad Toyota is getting the message that they need more range though.Rumors of 8 gallon aux tank?
Definitely a new sheriff in town
Is it not a torsen center diff?Side note: getting the full-time transfer case with the center diff - it's obviously strong enough
That would be great! Any source on the aux tank rumor?Crazy that they'd still only have 26 gallons. The new patrol has 39 gallons in the std tank. I'm glad Toyota is getting the message that they need more range though.
If you have seen the tundra/sequoia hybrid, its exactly the same. Toyota unlike ford believes the battery should be inside the cabin for longevity. Of course just like the sequoia, and this is smaller, the same internal constraints/sacrifices exist. The only new kit is that they included an alternator/starter two pieces meant as emergency only kit. I do wonder if they have a program logic that will cycle these two at regular interval or will they just bake until they are needed. The longevity of the hybrid system has traditionally been eliminating unnecessary ice vestiges but this hybrid application seem to be readding them.I wonder what the battery being located "in the rear floor" means..like is it partially above and below the floor with a clamshell waterproof structure getting flanged into the floor? The water fording depth is reported at 700 mm (28") (compare to 900mm - 35" for Land Rover Defender) which is probably pretty close to the top of the actual wheel (before getting back into the tire on the top side of the wheel/tire assembly).
"The vehicle features a waterproof structure that encases the hybrid main battery, located in the rear floor, within a waterproof tray divided into upper and lower sections."
Also interesting that when the hybrid system fails the LX has both a starter and alternator (unlike other hybrid Lexus vehicles) so it can still power itself completely without the motor generator and main hybrid batter functioning.
"Additionally, this is the first Lexus system to feature both an alternator and a starter as standard components, a departure from previous Lexus parallel hybrid models. In the event of a hybrid system failure, the starter enables independent engine ignition, while the alternator powers the 12V auxiliary battery, allowing the vehicle to continue driving using only the engine. Even in this emergency driving mode, essential features such as the transfer case's Lo-range, ride height adjustment using Active Height Control (AHC*1), and Active Traction Control (A-TRAC) remain fully operational, ensuring continued off-road capability."
