NeverFinis
I will update this post for key posts on the LS Swap. I will update when I have time.
Key LS Swap Posts.
Motor Mounts
Air Conditioning
Oil Pressure Gauge
Water Temp Gauge
GM Accelerator Pedal
Fuel Pump (about half way down post)
Toyota Tach Adjustment and Testing Toyota Tach
Transmission Dash Lights
Transmission Shifter, Transmission Shifter 2, Transmission Shifter 3
Transmission Shifter Cable Adjustment
Cluster Dummy Charge Light
Evap Vent Solenoid
Things I would Change
I made a decision a few months back and I have been on a shopping spree.
Starting a build thread for my triple locked LX450. Goal is to have an expedition vehicle that is reliable, robust and comfortable that we can enjoy. It won't be a rock crawler but it should be able to take us to most remote locations and have camp setup within 10-20 minutes after we stop driving for the day.
Starting with:
Already installed are OME heavy 2.5" springs and shocks, slee-offroad caster correction bushings, extended brake lines, and Ron Davis radiator. Not installed but currently have: 8K winch and 42 gallon aux LRA tank. I would rather have a larger winch, but it will do. I don't want to be in a situation where winching is a real possibility.
Arrived: Penthouse XL Tent
Arrived: Ostrich Wing Awning
Arrived: Drawer Kit
Arrived: Tailgate Storage Lid
Some of the above was part of a recent group buy from Rugged Bound, which started the whole buying frenzy. "in for a penny, in for a pound"
I decided to swap in a LS L96 + 6L80/6L90. The L96 is considered an expedition motor with an iron block. It is rated for commercial duty and severe use. Extremely simple engine with modern technology. The more I read about the LS96, the more I like it. I am not a chevy person at all, but the tech improvements of the LS/LT motors has been impressive. This swap will come later. I am not a fan of the 1FZ-FE engine. IMHO, it is underpowered, inefficient, and unreliable. Rebuilding a 1FZ-FE is just putting lipstick on a pig.
I will need to build a kitchen setup, and something for water storage. For the latter, I am thinking of a water tank that is under belly, between the passenger frame rail and body, after the exhaust crossover, to keep weight low, rather than the typical cans on the rear bumper. That penthouse tent is 193 lbs and it is high. I will probably only put a flexible solar panel on top and maybe recovery boards.
Speaking of rear bumper, one side will be a tire carrier, but the other side I am thinking of an aluminum storage box like the gallery or deluxe box from Aluminess.
Arrived: Delta VS Front Bumper
Arrived: Delta VS Rear Bumper
A stainless steel filler neck from otramm arrived.
A new replacement galvanized gas tank arrived from Rock Auto.
There is rust behind the passenger side wheel well. I haven't inspected the driver's side yet. I guess that is common place for rust to be. I can't find patch panels
I am removing the factory roof racks in preparation for the RTT and load bars... And rust...but I don't think it is too bad. I will sand down and weld them shut. I have a Plug Weld tool on order to help with this.
Worst two spots below. My goal today is to remove the headliner to get access to underneath. BTW, the wind deflector mount was perfectly designed to hold water to slowly drip into that Rivnut.. Both of them had standing water inside....
