LX 470 Technical Service Bulletins (TSBs) (1 Viewer)
Gleneagle, CO
Listed below are all the LX 470 TSBs (technical service bulletins) listed on the US National Highway Transportation Safety Administration website as of February 2007. This may not be all or even most of the bulletins issued by Lexus/Toyota. If you are aware of any other bulletins let me know by PM and I'll add them.
Note that the Lexus TSBs are not identical to the Toyota TSBs for the 100 (LC 100 TSB Thread). I suggest looking at both lists if your problem system is common to both vehicles. In some years Lexus issued "General" TSBs in addition to model specific ones. I have included them if they looked to be relevant from the summaries.
I will add a "MUD Notes:" line with any info that will be useful for board members that is not contained in the summary. For an example see the "MINIMIZING TRANSFER CASE NOISE" near the middle of the 1998 list. This info should be from an authoritative source (i.e. the TSB) and could include a link to a forum thread focused on the TSB. If you have information and/or experiance with a particular TSB and are willing to help other board members then I will list you as a PM contact if you want.
I found this Edmunds.com article on TSBs very informative and recommend that you read it.
You, Your Vehicle and the Technical Service Bulletin (TSB) (from Edmunds.com)
Hope you find this useful. :)
Safety Recall for Lexus LX470 2003-2007 Models
Lexus Announces Intent to Voluntarily Recall Certain LX 470 Vehicles to Address Potential for Steering Shaft Disengagement
TORRANCE, Calif., July 29, 2010 -- Toyota Motor Sales (TMS), U.S.A., Inc., today announced that Lexus intends to conduct a voluntary safety recall of approximately 39,000 2003-2007 Model Year LX 470 vehicles to address a steering shaft condition. No other Toyota or Lexus vehicles are involved in this safety recall.
This action follows an announcement made by Toyota Motor Corporation in Japan on July 29, 2010.
Lexus has determined that the construction of the steering shaft on involved LX 470s is such that the snap ring on the shaft may disengage when the vehicle experiences an unusually severe impact to the front wheels, such as striking a deep pothole. If the snap ring becomes disengaged and the steering wheel is then repeatedly turned to the full locked position, the steering shaft may disengage over time.
Lexus is not aware of any accidents related to this condition.
“At Lexus, we are committed to setting a new standard for quality customer care and aggressive attention to the safety of our drivers,” said Mark Templin, group vice president and general manager of Lexus. “Our engineers have thoroughly investigated this issue and have identified a robust and durable remedy that will help prevent this condition from affecting drivers in the future.”
The remedy for this condition involves replacing the snap ring with a newly designed one and the installation of an additional component to prevent separation of the steering shaft.
Lexus will begin sending out notification to owners of involved vehicles by first class mail beginning in mid-August 2010, advising them to bring their vehicles to their local Lexus dealer to have this remedy performed at no charge.
Detailed information about this recall is available through Lexus Customer Satisfaction at 1-800-25 LEXUS or 1-800-255-3987 or at Lexus Recall Information.
MUD Thread:Lexus Steering Recall
Safety Recall for Lexus LX470 1998-2005 Models
Summary: CERTAIN SPORT UTILITY VEHICLES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THE DAYTIME RUNNING LIGHTS DO NOT MEET LUMINOUS INTENSITY STANDARD.
Make : LEXUS Model : LX470 Year : 1999 Manufacturer : TOYOTA MOTOR NORTH AMERICA, INC. NHTSA CAMPAIGN ID Number : 04V434000 Recall Date : SEP 07, 2004
Component: EXTERIOR LIGHTING:HEADLIGHTS Potential Number Of Units Affected : 75395
Consequence: THIS CONDITION COULD BLIND THE DRIVER OF A VEHICLE DRIVING IN THE OPPOSITE DIRECTION, INCREASING THE RISK OF A CRASH.
Remedy: DEALERS WILL INSTALL A RESISTOR, WHICH WILL DECREASE THE LUMINOUS INTENSITY OF THE DRL. OWNER NOTIFICATION BEGAN JUNE JUNE 10, 2005. OWNERS SHOULD CONTACT LEXUS AT 1-800-255-3987.
Notes: LEXUS RECALL NO. SSC 5LB. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-327-4236.
Australian Safety Recall for LX470 and LC100 - Front Disc Brake Rotor Retaining Bolt
Toyota—Land Cruiser and Lexus—Front Disc Brake Rotor Retaining Bolt
PRA number: 2007/9087 Date created: 1st March 2007
Land Cruiser 7#. Model Code FZJ78, FZJ79, HZJ78, HZJ79, HDJ78, HDJ79. Land Cruiser 10#. Model Code FZJ105, HZJ105, UZJ100, HDJ100. Lexus LX470. Model Code UZJ100. Production period 30 September 1997 through 5 December 2005.
When vehicle is operated under severe conditions with repetitive high "G" brake application forward and backward, excessive forces applied to the brake rotor may loosen the front brake rotor bolt/s. If vehicle operation continues in this condition, one or more bolts may loosen further (unwind) and eventually rattle free.
What should consumers do? All owners of affected vehicles will be contacted individually by letter.
Other regulator reference numbers: 7531A
Australian Safety Recall for LX470 and LC100 - Dash Board Harness
Toyota—Land Cruiser 100 and Lexus LX470—Dash Board Wire Harness Interference with Pedal Support
PRA number: 2008/10050 Date created: 26th May 2008
What are the defects? On certain Land Cruiser 100 and Lexus LX470 vehicles, there is a possibility that the dash board wire harness may be abnormally twisted changing its intended routing in the vehicle allowing contact with the unprotected edge of the pedal support bracket. If the vehicle is continuously driven on corrugated roads in this condition, the wire harness will rub against the pedal support bracket damaging the wire insulation cover resulting in a short circuit and blown fuse.
Other regulator reference numbers: 8515D
Australian Safety Recall for 2002 - August 2007 Models
Toyota—Land Cruiser 100 Series & Lexus LX470 Steering Intermediate Shaft Snap Ring
PRA number: 2010/11856 Date created: 30th July 2010
Target Number: 4,368 Recall Campaign: 0523G
Toyota Land Cruiser 100
Model Code: HDJ100, VIN: JTEHC05J# 04030122 - 04042432
Model Code: UZJ100, VIN: JTEHT05J# 02080021 - 02117147
Production: May 2005 - August 2007
Lexus LX470
Model Code: UZJ100, VIN: JTJHTOOW# 03523007 - 04029736
Production: July 2002 - August 2007
What are the hazards? If the snap ring becomes disengaged and the steering is then repeatedly turned to the full lock position, there is a possibility that the steering shaft may dislodge, which could result in loss of steering causing an accident.
What are the defects? On certain Land Cruiser Saraha 100 and Lexus LX470 vehicles, the construction of the steering shaft is such that the snap ring on the shaft may disengage when the vehicle experiences an unusually severe impact to the front wheels (for example, striking a deep pothole in the roadway).
Australian Safety Recall for 1998-2005 Models
Toyota - Land Cruiser and Lexus470 - Front Disc Brake Rotor Retaining Bolt
Date: 01/03/2007 Campaign Number: 7531A Recall Market Coverage: Australia
Toyota Motor Corporation Australia Limited
Product Model: Land Cruiser 78, 79, 100 & 105 Series & Lexus LX470 Target Number: 137,479
Model Years From: 1997 to 2005
Serial Range: Land Cruiser 10#. Model Code FZJ105, HZJ105, UZJ100, HDJ100. Lexus LX470. Model Code UZJ100. Production period 30 September 1997 through 5 December 2005.
Consequences: In the worse case of all bolts on one side displacing, continuous vehicle operation may result in brake pull.
Defect Details: When vehicle is operated under severe conditions with repetitive high "G" brake application forward and backward, excessive forces applied to the brake rotor may loosen the front bake rotor bolt/s. If vehicle operation continues in this condition, one or more bolts may loosen further (unwind) and eventually rattle. Owners of affected vehicles will be contacted individually by letter. - Info at Product Recalls Austalia
MUD Thread: Front Rotor bolt recall/replacement
1998 TSBs for the Lexus LX470 - NHTSA TSB listings (2/20/2006)
POWER STEERING GEAR. REPAIR MANUAL CORRECTION
Service Bulletin : 5174B - SEP 06, 2005 NHTSA Item Number: 10016962
Component: STEERING:HYDRAULIC POWER ASSIST SYSTEM
EXHAUST RATTLE
Service Bulletin : 00100 - JUN 23, 2004 NHTSA Item Number: 10008390
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL:CATALYTIC CONVERTOR
MUD Thread: Cat shields - Rattle Noise
EXHAUST BOOMING AT IDLE
Service Bulletin : 00104 - FEB 20, 2004 NHTSA Item Number: 10006197
TILT/TELESCOPIC STEERING NOISE/SMOOTHNESS IMPROVEMENT FOR STEERING COLUMN NOISE
Service Bulletin : 00204 - JAN 07, 2004 NHTSA Item Number: 10005738
Service Bulletin : ST00501 - DEC 14, 2001 NHTSA Item Number: 628664
Service Bulletin : ST00100 - MAR 17, 2000 NHTSA Item Number: 611191
Service Bulletin : 010199 - JAN 01, 1999 NHTSA Item Number: 605373
Component: STEERING
MUD Thread: LX 470 telescoping steering wheel questions
BALL JOINT INSPECTION METHOD
Service Bulletin : 01202 - OCT 11, 2002 NHTSA Item Number: 10000251
Component: SUSPENSION
CONTINUOUS ALARM NOISE FROM COMBINATION METER, DOOR MIRROR OPERATION INOPERATIVE OR MOVES INCORRECTLY
Service Bulletin Num : EL00202 - FEB 22, 2002 NHTSA Item Number: 629360
Component: ELECTRICAL SYSTEM
MUD Notes: Very loud warning buzzer from combination meter. Buzzer scares wife and costs $1150. :eek:
FRONT BRAKE VIBRATION
Service Bulletin : BR00401 - NOV 02, 2001 NHTSA Item Number: 627146
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS: DISC
IMPROVED REAR VIEW MIRROR ASSEMBLY AND MIRROR CONTROL ELECTRONIC CONTROL UNIT
Service Bulletin : EL00601 - OCT 19, 2001 NHTSA Item Number: 631713
Component: VISIBILITY:REARVIEW MIRRORS/DEVICES
PREVENTING PARTICLE BUILDUP AND PRESERVING THE APPEARANCE OF THE SHOULDER BELT ANCHOR
Service Bulletin : BO00901 - AUG 10, 2001 NHTSA Item Number: 622252
Component: SEAT BELTS:FRONT:ANCHORAGE
MUD Thread: Seat belt does not retract properly
NEW SEAT BELT TONGUE PLATE STOPPER SERVICE PARTS
Service Bulletin : BO00501 - MAR 23, 2001 NHTSA Item Number: 619119
REAR BRAKE SQUEAL NOISE
Service Bulletin : BR00201 - MAR 23, 2001 NHTSA Item Number: 627079
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS: DRUM
STEERING WHEELNUT SERVICE SPECIFICATION
Service Bulletin : ST010101 - FEB 16, 2001 NHTSA Item Number: 619796
Component: STEERING
MINIMIZING TRANSFER CASE BUZZ NOISE
Service Bulletin : NV00101 - JAN 05, 2001 NHTSA Item Number: 616649
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:COLUMN SHIFT
MUD Notes : To address TCase buzz at lowspeed/moderate acceleration and highspeed/light acceleration Toyota modified the "Highspeed Output Gear", "Shift lever and Linkage" and the "Center differential case" (ie.. the whole Tcase). The fix to the problem if you have it is to R&R the entire works. 7.4 hrs. Covered under 6yr/60k powertrain warranty if there is a specific customer complaint. New t-cases installed from VIN JT3HT05J#Y0114609. If you have questions PM Zimm or NMuzj100 with your email address.
MUD Thread : Transfer replaced under TSB
A/C CONDENSER FAN CONTINUES TO RUN AFTER THE IGNITION IS TURNED OFF DUE TO CORROSION IN THE RELAY CONNECTOR
Service Bulletin : AC00200 - AUG 11, 2000 NHTSA Item Number: 615956
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
SEAT HEATER REPLACEMENT PROCEDURE
Service Bulletin : BO00100 - APR 28, 2000 NHTSA Item Number: 612529
Component: SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER
CHANGE TO REDUCE WIND NOISE FROM UPPER REAR CORNER OF THE FRONT PASSENGER SIDE WINDOW
Service Bulletin : NV00200 - JAN 07, 2000 NHTSA Item Number: 610098
Component: VISIBILITY:WINDSHIELD
BLOWER MOTOR IMPROVED DURABILITY
Service Bulletin Num : AC00499 - OCT 15, 1999 NHTSA Item Number: 6088671
Component: VISIBILITY: DEFROSTER/DEFOGGER SYSTEM
VEHICLES STARTING WITH VIN JT6HT00W**X0041301 MAY EXPERIENCE REAR BRAKE SQUEAL NOISE
Service Bulletin : BR00599 - SEP 24, 1999 NHTSA Item Number: 607892
REAR VIEW MIRROR AUTO DOWN IN REVERSE FEATURE - OUT OF ADJUSTMENT
Service Bulletin : EL00799 - SEP 17, 1999 NHTSA Item Number: 607888
Component: VISIBILITY:POWER WINDOW DEVICES AND CONTROLS
SCANTOOL IMMBOLIZER KEY CODE UTILITY
Service Bulletin : SS00699 - JUN 18, 1999 NHTSA Item Number: 606226
Component: ELECTRICAL SYSTEM:IGNITION:ANTI-THEFT CONTROLLER
TRAILER TOWING WIRE HARNESS CONVERTER REPLACEMENT AND RELOCATION
Service Bulletin : 140599 - MAY 14, 1999 NHTSA Item Number: 606667
Component: EQUIPMENT:MECHANICAL:WRECKER AND WHEEL LIFT DEVICES
CORRECTIONS MADE TO REPAIR MANUALS
Service Bulletin : PG01399 - MAY 14, 1999 NHTSA Item Number: 622017
Component: OTHER
PARKING BRAKE ADJUSTMENT PROCEDURE TO REDUCE RATTLE NOISE
Service Bulletin : BR00399 - APR 02, 1999 NHTSA Item Number: 604944
Component: PARKING BRAKE:CONVENTIONAL:MECHANICAL
REAR CUP HOLDER MODIFICATION
Service Bulletin : BO00199 - MAR 26, 1999 NHTSA Item Number: 604675
Component: OTHER
ABNORMAL NOISE FROM A/C EXPANSION VALVE
Service Bulletin : AC00199 - FEB 12, 1999 NHTSA Item Number: 604649
Service Bulletin : 010199 - JAN 01, 1999 NHTSA Item Number: 605383
MUD Thread : AC Groan or Growl
SCANTOOL KEY CODE UTILITY
Service Bulletin : 010199 - JAN 01, 1999 NHTSA Item Number: 609100
SQEAK & RATTLE IN THE CENTER CONSOLE AREA
Service Bulletin : NV01498 - SEP 18, 1998 NHTSA Item Number: 603844
Component: STRUCTURE:BODY
REPAIR PROCEDURES TO REDUCE WIND WHISTLE OR TURBULENCE NOISE FROM THE SIDE MARKER LAMP, OUTER REAR VIEW MIRROR, AND / OR RADIATOR GRILLE
Service Bulletin : NO01298 - AUG 21, 1998 NHTSA Item Number: 602270
FRONT SUSPENSION BUZZ NOISE
Service Bulletin : NV01398 - AUG 21, 1998 NHTSA Item Number: 602272
Component: SUSPENSION:FRONT
A343F ATM 1-2, 3-4 SHIFT IMPROVEMENTS
Service Bulletin : TC00498 - AUG 07, 1998 NHTSA Item Number: 602278
FUSE INSTALLATION DURING PDS
Service Bulletin : PG00298 - JAN 30, 1998 NHTSA Item Number: 600200
Component: ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
1999 TSBs for the Lexus LX470 - NHTSA TSB listings (2/20/2006)
Component: SERVICE BRAKES, HYDRAULIC:POWER ASSIST
EXHAUST RATTLE
Component: STEERING
SPARE TIRE CARRIER OPERATION
Service Bulletin : PG00403 - AUG 19, 2003 NHTSA Item Number: 10003556
Component: TIRES:TEMPORARY/EMERGENCY SPARE TIRE
Service Bulletin : EL00202 - FEB 22, 2002 NHTSA Item Number: 629360
Service Bulletin Num : BR00201 - MAR 23, 2001 NHTSA Item Number: 627079
Component: STEERING
MUD thread: Transfer replaced under TSB
RATTLE NOISE FROM THE ROOF RACK
Service Bulletin Num : AX00699 - DEC 24, 1999 NHTSA Item Number: 610104
Service Bulletin : AC00499 - OCT 15, 1999 NHTSA Item Number: 6088671
REPAIR MANUAL CORRECTIONS
Component: OTHER
Service Bulletin : BO00199 Date of Bulletin: MAR 26, 1999 NHTSA Item Number: 604675
Component: OTHER
REAR BUMPER FASCIA REINFORCEMENT INTERFERES WITH THE CLEARANCES AROUND THE TOWING HITCH
Service Bulletin : AX00299 - MAR 12, 1999 NHTSA Item Number: 604656
Component: STRUCTURE:BODY:BUMPERS
NOISE REDUCTION AND IMPROVED SMOOTHNESS OF THE TILT / TELESCOPIC STEERING COLUMN ASSEMBLY
Service Bulletin : ST00299 - MAR 05, 1999 NHTSA Item Number: 604658
Component: STEERING:COLUMN
ECU-B1 FUSE PRODUCTION CHANGE FOR VEHICLES STARTING WITH VIN JT6HT00W*X0037662
Service Bulletin : EL00199 - FEB 19, 1999 NHTSA Item Number: 604648
TOWING HITCH INSTALLATION INSTRUCTION AMENDMENT
Service Bulletin : 010199 - JAN 01, 1999 NHTSA Item Number: 605377
SCANTOOL KEY CODE UTILITY.
FUSE INSTALLATION DURING PDS.
Service Bulletin : PG00598 - AUG 28, 1998 NHTSA Item Number: 602273
2000 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
Service Bulletin Num : 5174B - SEP 06, 2005 NHTSA Item Number: 10016962
Service Bulletin Num : 00104 - FEB 20, 2004 NHTSA Item Number: 10006197
Service Bulletin Num : 00204 - JAN 07, 2004 NHTSA Item Number: 10005738
Service Bulletin Num : ST00501 - DEC 14, 2001 NHTSA Item Number: 628664
Component: STEERING
Service Bulletin Num : PG00403 - AUG 19, 2003 NHTSA Item Number: 10003556
Service Bulletin Num : 01202 - OCT 11, 2002 NHTSA Item Number: 10000251
Service Bulletin Num : BR00401 - NOV 02, 2001 NHTSA Item Number: 627146
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:DISC
Service Bulletin Num : EL00601 - OCT 19, 2001 NHTSA Item Number: 631713
PREVENTING PARTICLE BUILDUP AND PRESERVE THE APPEARANCE OF THE SHOULDER BELT ANCHOR
Service Bulletin Num : BO00901 - AUG 10, 2001 NHTSA Item Number: 622252
CONTINOUS CHIME/ALARM NOISE EMITTING FROM THE COMBINATION METER AFTER THE VEHICLE HAS BEEN STARTED OR THE KEY IS IN THE RUN POSITION
Service Bulletin Num : EL00301 - JUN 08, 2001 NHTSA Item Number: 622175
Service Bulletin Num : BO00501 - MAR 23, 2001 NHTSA Item Number: 619119
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:DRUM
Service Bulletin Num : ST010101 - FEB 16, 2001 NHTSA Item Number: 619796
Component: STEERING
Service Bulletin Num : NV00101 - JAN 05, 2001 NHTSA Item Number: 616649
Service Bulletin Num : AC00200 - AUG 11, 2000 NHTSA Item Number: 615956
ELECTRICAL WIRING DIAGRAM AMENDMENT - ADDITION OF THE TRAILER CONVERTER CIRCUIT
Service Bulletin Num : EL00200 - APR 14, 2000 NHTSA Item Number: 621562
2000 Lexus General TSBs
CLICKING TYPE NOISE WHEN FIRST APPLYING THE BRAKES AFTER CHANGING VEHICLE TRAVEL DIRECTION (DRIVE / FORWARD TO REVERSE, REVERSE TO DRIVE / FORWARD)
Service Bulletin Num : BR00300 - OCT 20, 2000 NHTSA Item Number: 618465
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS :DISC:PADS
Service Bulletin Num : BO00100 - APR 28, 2000 NHTSA Item Number: 612529
ENGINE IMMOBILIZER SYSTEM PRECAUTIONS
Service Bulletin Num : EL00899 - DEC 10, 1999 NHTSA Item Number: 610101
2001 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
Component: STEERING
IMPROVEMENT TO IGNITION CYLINDER PERFORMANCE
Service Bulletin Num : 00503 - MAY 23, 2003 NHTSA Item Number: 10002015
IMMOBILIZER KEY CODE RESET
Service Bulletin Num : 00201 - AUG 26, 2002 NHTSA Item Number: 10001173
IN-MIRROR COMPASS INOPERATIVE
Service Bulletin Num : EL00702 - JUL 05, 2002 NHTSA Item Number: 633796
Component: VISIBILITY:REARVIEW MIRRORS/DEVICES:INTERIOR
CONTINUOUS ALARM NOISE FROM COMBINATION METER, DOOR MIRROR INOPERATIVE OR MOVES INCORRECTLY
TILT/TELESCOPIC STEERING NOISE/SMOOTHNESS IMPROVEMENT UPDATE
Component: STEERING
PROBLEMS REGARDING THE MARK LEVINSON SOUND SYSTEM
Service Bulletin Num : AU00101 - OCT 12, 2001 NHTSA Item Number: 627139
Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
ECU FLASH REPROGRAMMING PROCESS
Service Bulletin Num : SS00101 - MAR 09, 2001 NHTSA Item Number: 619115
Component: ELECTRICAL SYSTEM:IGNITION:MODULE
2002 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
Component: STEERING
FLASHING AHC (ACTIVE HEIGHT CONTROL) OFF LIGHT WITH DIAGNOSTIC TROUBLE CODE C1743
Service Bulletin Num : SU00203 - SEP 12, 2003 NHTSA Item Number: 10003971
SOME MARK LEVINSON AMPLIFIERS MAY NOT PRODUCE SOUND WHEN THE AUDIO SYSTEM IS ON
Service Bulletin Num : AU00202 - APR 02, 2002 NHTSA Item Number: 633768
REPAIR MANUAL SUPPLEMENT - VEHICLE PULLING TO ONE SIDE
Service Bulletin Num : 00401 - DEC 21, 2001 NHTSA Item Number: 10017720
Component: STEERING
2002 Lexus General TSBs
VEHICLE PULLING DIAGNOSIS AND REPAIR PROCEDURES ALONG WITH SPECIFIC INFORMATION TO HELP CORRECT PULLING COMPLAINTS
Service Bulletin Num : ST00401 - DEC 21, 2001 NHTSA Item Number: 628667
2002 MODELS, VEHICLE PULLING TO ONE SIDE
Service Bulletin Num : ST00401 - NOV 16, 2001 NHTSA Item Number: 627151
Component: STEERING
RECOMMENDED ADJUSTMENT PROCEDURE FOR CORRECTING AN OFF-CENTER STEERING WHEEL
Service Bulletin Num : ST00201 - SEP 21, 2001 NHTSA Item Number: 625524
Component: STEERING
2003 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
https://forum.ih8mud.com/100-series-cruisers/402686-fyi-toyota-recall-39-000-2003-2007-lx470s.html
WARRANTY COVERAGE ENHANCEMENT - FRONT (NIGHT VIEW) CAMERA 2003--EARLY 2004 LX470s
Service Bulletin Num : 0703 - OCT 22, 2007 NHTSA Number : 10023672
Component :UNKNOWN OR OTHER
RAIN SENSOR SYSTEM - REPAIR MANUAL CORRECTION 05-03 LX470
Service Bulletin Num : 5156 - AUG 30, 2005 NHTSA Item Number: 10016597
LIMITED SERVICE CAMPAIGN (LSC) 4LD - LEXUS LINK SYSTEM REMOVAL. CAMPAIGN DETAILS AND TECHNICAL INSTRUCTIONS
Service Bulletin Num : 4 - AUG 06, 2004 NHTSA Item Number: 10010434
JUMP STARTING VEHICLES EQUIPPED WITH CRANK HOLD FEATURE
Service Bulletin Num : 00104 - MAR 03, 2004 NHTSA Item Number: 10006549
Component: STEERING
LEXUS LINK SYSTEM ERROR DETECTED
Service Bulletin Num : EL00903 - AUG 21, 2003 NHTSA Item Number: 10003573
SPECIAL SERVICE CAMPAIGN 3LF TO INSPECT AND/OR REPLACE THE THROTTLE BODY ASSEMBLY. AN ELECTRICAL CONTACT IN THE THROTTLE BODY MOTOR MAY MALFUNCTION CAUSING THE MALFUNCTION INDICATOR LIGHT (MIL) TO ILLUMINATE ON THE DASH AND THE ENGINE CONTROL MODULE (ECM) TO STORE A TROUBLE CODE AND PLACE THE VEHICLE INTO A LIMP HOME MODE
Service Bulletin Num : 3LF - JUL 24, 2003 NHTSA Item Number: 10003487
Component: VEHICLE SPEED CONTROL
VARIABLE GEAR RATIO STEERING (VGRS) CALIBRATION PROCEDURE
Service Bulletin Num : ST00103 - JUN 19, 2003 NHTSA Item Number: 10003371
Component: STEERING
WIRELESS HEADPHONE UNEXPECTEDLY TURNS OFF DURING LOW TEMPERATURE OPERATION
Service Bulletin Num : 00403 - MAY 12, 2003 NHTSA Item Number: 10002011
BUZZ NOISE ON THE LAND LINE SIDE DURING A HANDS-FREE CALL
Service Bulletin Num : 00303 - MAY 09, 2003 NHTSA Item Number: 10002010
DAYTIME RUNNING LIGHTS STAY ON WHEN TOWING A TRAILER
Service Bulletin Num : 00303 - APR 25, 2003 NHTSA Item Number: 10001537
2003 LX470 REPAIR MANUAL CORRECTION - WIRELESS DOOR LOCK CONTROL SYSTEM - VOL II
Service Bulletin Num : 032503 - MAR 25, 2003 NHTSA Item Number: 10001315
SERVICE MAINTENANCE REMINDER LIGHT RESET PROCEDURE
Service Bulletin Num : 00203 - MAR 10, 2003 NHTSA Item Number: 10001313
REPAIR MANUAL CORRECTION - ELECTRICAL WIRING DIAGRAM
Service Bulletin Num : 030503 - MAR 05, 2003 NHTSA Item Number: 10001316
A750 TRANSMISSION SOLENOID IDENTIFICATION
Service Bulletin Num : 00103 - FEB 28, 2003 NHTSA Item Number: 10001310
DIAGNOSTIC TESTER IMMOBILIZER FUNCTIONS
Service Bulletin Num : 00501 - JAN 09, 2003 NHTSA Item Number: 10001049
INITIALIZATION OF VGRS SYSTEM
Service Bulletin Num : 01102 - OCT 04, 2002 NHTSA Item Number: 10005257
Component: STEERING
THIS BULLETIN STATES THAT THE SHORT PIN USED TO MINIMIZE BATTERY DISCHARGE DURING TRANSPORTATION AND STORAGE, NEEDS TO BE RE-INSTALLED DURING PREDELIVERY SERVICE
Service Bulletin Num : PG01002 - SEP 12, 2002 NHTSA Item Number: 635747
Component: OTHER
INSTALLATION OF TOW HITCH RECEIVER DURING PRE-DELIVERY SERVICE
Service Bulletin Num : PG00802 - AUG 26, 2002 NHTSA Item Number: 633748
Component: TRAILER HITCHES
Component: STEERING
Summary:. ALL LEXUS'02 - '07 MODELS.
2003 General Lexus TSBs
BLANK MAP SCREEN IN NAVIGATION SYSTEM. ALL '03 MODELS WITH NAVIGATION SYSTEM
Service Bulletin Num : EL00603 - JUN 04, 2003 NHTSA Item Number: 10003366
Component: EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM (GLOBAL POSITIONING SYSTEM)
2004 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
WARRANTY COVERAGE ENHANCEMENT FOR 2004 THROUGH EARLY 2005 LX470s EQUIPPED WITH REAR (BACK-UP) CAMERA
Service Bulletin Num : 0702 - OCT 16, 2007 NHTSA Number : 10023695
Component : UNKNOWN OR OTHER
MALFUNCTION INDICATOR LIGHT ON DIAGNOSTIC TROUBLE CODE P2742 - 2004 LEXUS GX470
Service Bulletin Num : 01705 - NOV 08, 2005 NHTSA Item Number: 10018269
REPAIR MANUAL CORRECTION FOR THE MAINTENANCE - CHASSIS 04-05 LX470
Service Bulletin Num : 5240 - NOV 18, 2005 NHTSA Item Number: 10018695
HEIGHT SENSORS
Service Bulletin Num : 00204 - SEP 09, 2004 NHTSA Item Number: 10010142
Component: SUSPENSION:AUTOMATIC STABILITY CONTROL (ASC)
Summary: . *JB
DAYTIME RUNNING LAMPS. STOP SALE PROGRAM. LETTER TO DEALER PRINCIPAL; QUESTIONS & ANSWERS; TECHNICAL INSTRUCTIONS
Service Bulletin Num : 010104 - SEP 09, 2004 NHTSA Item Number: 10010153
MARK LEVINSON AUDIO SYSTEM STAYS MUTED AFTER ENDING BLUETOOTH WIRELESS PHONE CALL
Service Bulletin Num : 00104 - JAN 26, 2004 NHTSA Item Number: 10005799
MUD Thread: Bluetooth and Sound System TSB
BLUETOOTH / NAV SYSTEM VIRUS
Service Bulletin Num: 0401 - Feb 15, 2005
Mud Link:Security firm probes reports of car viruses - LX470 Targeted
MUD Thread:Bluetooth issues and Intermittent Nav problems in my Lexus
MUD Thread:Bugs in my Lexus ?
REPAIR MANUAL SUPPLEMENT - VEHICLE PULLING TO ONE SIDE ALL LEXUS '02 - '07 MODELS
Component: STEERING
2005 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
REPAIR MANUAL CORRECTION FOR THE AUTOMATIC TRANSMISSION FLUID. '04 & '05 LX470
Service Bulletin Num : 5243B - NOV 18, 2005 NHTSA Item Number: 10018702
ECM CALIBRATION UPDATE: MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0136 AND/OR P0156
Service Bulletin Num : 01606 - OCT 05, 2005 NHTSA Item Number: 10017661
Component: ENGINE AND ENGINE COOLING:ENGINE
'05 LX470 REPAIR MANUAL CORRECTION. DIAGNOSTICS - LEXUS NAVIGATION SYSTEM
Service Bulletin Num : 5145B - JUN 30, 2005 NHTSA Item Number: 10015508
Component: EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
REPAIR MANUAL CORRECTION. MAINTENANCE - UNDER HOOD
Service Bulletin Num : 4530 - JUN 06, 2005 NHTSA Item Number: 10015507
Component: OTHER
FIFTH GEAR SHUDDER
Service Bulletin Num : 00105 - JAN 28, 2005 NHTSA Item Number: 10015189
SUNROOF WIND DEFLECTOR GASKET FIT
Service Bulletin Num : 00205 - JAN 25, 2005 NHTSA Item Number: 10015190
Component: VISIBILITY:SUN ROOF ASSEMBLY
HEIGHT SENSORS
HEADLAMP WASHER SYSTEM
Service Bulletin Num : 30 - APR 01, 2004 NHTSA Item Number: 10012928
REPAIR MANUAL SUPPLEMENT - VEHICLE PULLING TO ONE SIDE. ALL LEXUS '02 - '07 MODELS
Component: STEERING
2006 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
ILSAC GF-4 ENGINE OIL STANDARD. '06 LEXUS - RECOMMENDATION
Service Bulletin Num : 00106 - MAR 29, 2006 NHTSA Item Number: 10019327
MALFUNCTION INDICATOR LAMP ON DIAGNOSTIC TROUBLE CODE P0171, P0174, P2195, OR P2197
Service Bulletin Num : 01805 - NOV 17, 2005 NHTSA Item Number: 10018276
DISMOUNTING TIRES WITH DIRECT SYSTEM PRESSURE SENSORS
Service Bulletin Num : 00505 - JUL 22, 2005 NHTSA Item Number: 10017114
Component: TIRES
TIRE PRESSURE SENSING TRANSMITTER ACTIVATION PROCEDURE
Service Bulletin Num : 02105 - MAY 26, 2005 NHTSA Item Number: 10016435
Component: TIRES
HEIGHT SENSORS
Component: STEERING
2007 TSBs for the LX470 - NHTSA TSB listings (2/20/2006)
Component: STEERING
If you have information on a TSB to add or know of a good thread that deals with one then send me a PM.
thanks alot for this i had a little problem with my ahc sometimes when i am at a stop light or parked and putting the lids in the car seat the height control activates not muuch but i can hear it and even see that the truck is not level i will bring thsi up at my next service thansk again
