OK, LX 470 Low Beam bulb replacement:
Get a wrench and release the bolt battery tie-down bar from the front vehicle frame - keep pressure on bar when removing bolt to prevent bar from springing up (throwing bolt/hitting part of engine/dropping into not-so-easy-to-get-to places) remove and set aside.
Push battery as far back (towards drivers seat) in its tray as possible - may have to lift it up and rest it on the tray lip.
On the back of the headlamp housing, find a beige/gray plastic circle with flanges, rotate this Counter-Clockwise to unlock, pull out of socket and hold.
At this point, you can see the electrical connector on the back of the bulb - the wire runs through the plastic cover you just removed, which doesn't leave much play in the wire, so to avoid undue stress to the wire/connector, remove the connector from the bulb before proceeding.
After connector removed from bulb tab, depress spring clip toward front of vehicle and down to release. Rotate spring clip on its hinge and the bulb is exposed and loose.
After installing bulb, follow instructions in reverse.
Take care that the bulb is properly seated in the holder before re-engaging spring clip.
Electrical connector cannot be improperly applied.
Ensure plastic cover is tight to prevent water/dirt contamination.
As the packaging says, NEVER touch bulb glass with bare hands, metal is ok. The reason for this is that oils in your skin will leave residue on the bulb, and later cause fire/explosion when the bulb is lit.
When re-tightening battery tie-down bar, take care to replace battery to previous location in tray, and maneuver to be able to tighten bar down flush with frame without putting major stress on battery (tight enough to keep from moving around, not too tight to bend the bar/dent the battery case)
Instructions are SAME for Passenger side, except for battery bar.
In case of beam projecting strangely/incorrectly, reseat bulb - if inordinate force is needed to replace spring clip, bulb is not correctly seated. When bulb is properly seated, almost no force is needed to replace spring clip.
Enjoy your new headlamps. And if going from OEM to H1ST, be prepared - it's like night and day!
-LX Pilot
