LukeZero
Deeply Confused
Wanted to bounce a couple of ideas off you guys. I have a 76 Cruiser based buggy that I'm losing my interest in. Partially I want to start over and do something more modest, more daily driverish. Partially this thread is to try to get a feel for what a fair price would be if I do decide to sell it. If you are offended by chat in Tech- look away now.
Buggy is 76 FJ40, 2F with Howell fuel injection (TBI). Transmission is SM420, ToyBox with 4.6 gears, minitruck T-case with Longfield Cro-Mo output shaft. Front axle is high pinion RockCrusher 60, 5.13 gears, ARB, Cro-Mo inners and outers, Longfield U joints. Poison Spider high steer arms, 6061 alum drag link and tie rod with 3/4" heims. West Texas Off Road hydro assist. Rear axle is 14 bolt, 5.13:1, ARB, disc brakes.
Suspension is modified 3 link with panhard bar in front, rear is 4 link. Long travel shocks and the coil springs are from a Jeep TJ. 6" lift springs in front, 4" lift springs in back. Lot's of articulation!
42 IROKs on new Raceline Monster beadlocks. 8 lug, 17".
Kirkey aluminum seats. Warn 8274 winch, full cage. Frame cut off behind seats, tube work starts there. Roll cage goes through firewall and picks up the front upper shock mounts.
Lowest crawl ratio is 418:1. Drives down the road really smoothly. Vaguely street legal. Has a windshield and brake lights. Licensed and plated in IN.
I have some other plans in mind, that don't include this truck. If I could cash out of this and head a different direction, it might be time to do that.
Between what the previous owner spent, and what I've done it probably has $30K in it. Would I be smoking crack to try to get $12,500? Hold out for more?
Part of my current frustration with it is that it needs some new gauges installed in the dash (which I have) but haven't installed. There is some wiring I'd like to clean up. But mostly, it is too capable for the obstacles we have in the Midwest. If I can't make an obstacle where I wheel, it is obviously driver incompetence. I can't blame it on the truck anymore!
Thoughts?
__________________
Thoughts?
__________________
