Lower Control Arms -- Rebush or Replace? (13 Viewers)
Yeah, I hate it, but I agree. I put Moogs on mine, hoping to get at least 100k out of them. Now, at 45k, they're nothing but loose garbage (and this is from 95% road use!) It's painful to spend what Toyota charges for most parts, but to spend less and then have to spend again (and again, and again) is sort of like cutting off a cat's tail little by little so it won't hurt so badly!
I resisted the "buy once, cry once" mantra for a long time, but it's actually quite true........
How often did you grease them?
You drive a Lexus not a Chevy. OEM parts are pricey because they’re built better and last longer. Moog is garbage.
Jiggle@#$? Is that you?? Welcome back!
OEM 460 arms must be pricy too no? I'd probably go with a Moog or a similar thing off Rock Auto.
$250 a piece off partsouq isn't bad to me. KDSS 470 arms are $400 there. OEM arms might last 300000 miles if driven sedately, I doubt moog will match that relative to the cost even.
My OEM arms had cracked bushings and floppy LBJs at 145k. They might have kept going but the performance was definitely degraded.
I pulled mine at 180 and the bushings were good visibly and still had little give. The LBJ could move easily but had no play.
Not gonna say leaving them for 300k is a great idea but a lot of high mile toyota have never had stuff like LCA's done.
I have KDSS on my 470 so $800 for a pair of arms is out of the question. I have already installed 555 LBJs into my OEM arms which are sitting in the 130k but the bushings are smoked.
I saw RedNexus used Moog and that was my inspiration. I can always keep my factory arms for later use, but if the Moog arm, and bushing is decent, I can always move my 555s over to those arms. Would love to go with a Moog 460 arm and save a ton of cash.
Here are my Moog LCA LBJs and bushings after ~30K of use. Zero issues. The greaseable joint does puke a bit of grease past the lower seal when I grease it at oil changes - just like any other greseable U-joint or slip yolk. When compared side-by-side the Moog LCAs are near-exact replica of the OEM UCA's, including the bushings. I'd get them again, but will also update this thread and my build thread if I have an issue with them in the future so there is a record of how long they actually do last. I have no idea of if these will need replacement at 60K or make it to 100K+ - only time will tell.
My GX does get wheeled and used harder than many, so these have seen a lot of non-pavement miles (washboard roads, occasionally getting a bit of air, lots of rocks, etc). I'm also lifted ~2.5" in the front. Since these have been good to me, we put a pair on a buddy's 1st gen Tundra (albeit with OEM Toyota LBJs given how failure-prone that style is) and they were also exact replicas of the OEM LCAs. They saved him a few hundred bucks as well.
I just replaced both LCA's on GX470 (@135k, non-KDSS, all original parts) with OEM Toyota 48069/48068-60010, purchased@local dealer for $900. After reading some on this site and watching several youtube videos, I saw there was usually some amount of drama associated with separating the ball joint from the ball joint "bracket" ("Attachment, Front Lower Ball Joint" = ~6" long metal part with two large screws that the ball joint presses into, affixed with a castle nut). I do not have a pickle fork or a separator tool but this was straightforward:
I marked the alignment tabs, unscrewed everything, removed the entire lower control arm with bracket attached. I put the LCA on the ground with the ball joint resting vertically on a plastic [tree] felling wedge (any relatively hard flat object would work) so the "bracket" would drop onto the felling wedge when it separated. I hit both sides of the bracket simultaneously with a 6lbs sledge and a splitting wedge. Bracket dropped right off after a couple of easy hits, maybe 1+ on a 10-scale of effort. Simple and far easier than most of what I've seen/read online. I should've taken a pic but with luck this explanation makes sense. Near zero rust or corrosion though I would imagine even with significant rust, this method would work with a little more effort.
I took my GX 470 07 model, to the shop and they said my control arms are shot, of course I was suppose to be there to see what they saw, but they did not call me, so now my car has been towed there and I am going to Lexus to get upper and lower control arms and ball joints, there is a 17% discount due to the 4th. of July sale.
The rear control arms do they fail like the front or 3 rd party parts are good for the back? Ca. rig 100% dealer maintained. 205K miles. Zero off road.
I have a 2003 GX470 and I recently replaced my rear upper and lower control arms, rear sway bar, rear sway bar end links, and panhard bar.
All but the panhard were upgraded parts for offroad. This after many years of off-roading with the stock parts.
Don’t worry about the rear suspension unless something is wrong (bent arm, torn bushing, broken arm). Spray some silicon spray from CRC or WD-40 onto the bushings to keep them from rotting.
The rear bushings are not as critical as the front ones. In the front, it affects your steering and alignment.
Thanks I found a Toyota dealer having about 33% off for the same part number that Lexus that is giving 17% off.
My GX has 206k miles, and the rear bushings were toast. I found some Gen 5 4Runner control arms with low miles for cheap, and threw in the lowers for now. The uppers don't have the height sensor tab. I'll swap them in when I go with springs.
