- Joined
- Jan 10, 2013
- Threads
- 16
- Messages
- 340
Probably going to have to rebuild mine since I have KDSS. Sounds like 460 arms require making the shock hole bigger? Was tempted to do Moog.
Already pressed 555s in to the factory arms but the stock bushings are smoked.
Yes, and 460 cam bolts.
I rebuilt mine. Even on my truck that is west coast and minimal rust the bushings were a bit of work. One popped out fairly easy, two took a lot of heat and work, and the last one had to be burned out entirely. Then on top of that I had to use an air hammer with a cutting tool to cut the liner out on two of the four as it was seized to the arm.
I wouldn't do it again, if I have the truck that long I'll do 460 arms and cam bolts.
