Lou's [it only needs a clutch] 1976 FJ40
new fuel lines run. and reRun. I decided to eliminate the mechanical pump I have been running and nix the idea of the power surge system. makes sense for me because I'm relocating the battery, adding a plenum and inline filter for the snorkel and also adding the lines and all for the vintage air. Man-A-Fre aluminum fuel tank in too to replace the downey poly tank.
also added a 4plus rear tire carrier and basket swing out
slowly but surely. ive only have one day and a Sunday or two to piddle....
looks like @orangefj45 has me about buttoned up on the trans and transfer case......
to quote Georg, "it was cobbled together very poorly" and he mentioned the use of early front half case, late rear half and different year gear sets and some shaft being cut off and a bushing being milled down to make it work...
t case - new housings, gears, and a proper shifter!
and then there's the whole issue of the rock in the transmission.......new synchro, gear set, and main shaft....
likely would have exploded next time I put it in 4Lo.....
@wngrog - thanks for the help.....
finishing up some wiring and only lack a few details.......still....taking my time and hoping I haven't forgotten anything.
Don't forget the gear oil! Just sayin...
Lou got busy since last Tuesday. Lots of little stuff done
Final wiring at the terminal end is all and plugging stuff in. I see this thing running in a week.
I helped him stab the exhaust and install driveshafts. Then we made AC hoses.
I think all he needs now is time to button it all up.
Dakota Box
This is the AC hose crimper.
Finished product. Slick.
Cool air cleaner that goes into the snorkel
Dakota and Sniper
so close.....I have about 5 12v switched wires and the battery connections left......re connect PS return and radiator hose fitment....
then fluids for those 2. bleed brakes and clutch....
then fire it up!
hope to get it up and running this week.
Boom. Growl. Spit. Slobber.
We had the dissy 180 out. Took us an hour or two to slow down and do it right.
After that it smashed.
Cockpit
Engine bay is tight
Cockpit
Engine bay is tight
Spectacular work @under_psi !!
