Looking for console, transmission(H150), shifter, shifter boot, bellhousing, clutch pedal assembly......all the rare stuff that is obsolete that everyone else is looking for. Maybe someone has a stash squirreled away somewhere. Trying to do a 5 speed conversion in a 91 FJ80. Thanks!
I have the full kit installed in my FJ80, MAY be tearing it out to install a 1HD-T and H151F. If I do end up tearing it out, it'll likely be the end of this year. If you're still looking then, and the first guy who was interested in it passes, I'll let you know. But I gotta say, the 3FE works so good with a 5 speed I'm tempted to just sell the 1HD-T.
I have a H150f transmission, transfer case and bell housing with adaptor plate for the 3fe
this uses the 2f flywheel and clutch
located in Atlanta.
pm if interested
located in Atlanta.
pm if interested
located in Atlanta.
pm if interested
This was the cross over transmission from 3f to 1fz, same spline as 2f 12ht.
It's been a long time since I searched in toyodiy. I'm pretty sure this was just used the 3yrs of the fj80.
I just checked toyodiy looks like it was just in the general market, it doesn't show in Japan or Europe so not sure what countries had this transmission
It came attached to a 3F with a carburetor.
It uses the adaptor plate below
Far as I know, they do use a different flywheel. The part numbers between an F series H42/55F flywheel and a 3F H150F flywheel are different I believe. A 2F flywheel can be modified to work with a 3FE/H55F combo (been done on this forum) but idk about 2F flywheel with H150F.
Looks like your right, the clutch disc, pressure plate and flywheel from a 3f 70 series 11/84 to 1/90 in N. America which has to be Canada
1/90 to 7/92 80 series and even shows 8/87 12/89 hj61 In Europe. and many more 70 series models with 3f. so this can be done.
So my mistake, 25 give or so yrs ago I had a 2f sitting on the floor.
I hooked this trans up with the adaptor everything went together fine input shaft same spline so the 2f disc slid right on the shaft.
So I assumed everything 2f would work, never assume.
Hi Bill, I recently acquired one of these 90-92 H151f's myself and wanted to confirm what you posted. I did a side-by-side of the 3F flywheel, clutch etc with pre 90 2F parts and you are correct, everything is interchangeable. The 3F flywheel is a few lbs lighter but otherwise functionally replaceable with 2F parts.
located in Atlanta.
pm if interested
91 or 92. No mods, no rust. I just want to drop my manual in it and have a nice driver. I swap a lot of 3FEs into 40s and with a manual behind them, nice motor with a manual. I have a super clean one that I bought the trans for but I'm going to swap a diesel and a manual in that little gem
Ideally a non-running 91/92 would be great as we have a ton of 3FEs to swap in. Seems nice clean 80s pop up with bad motors from time to time.
