Longfield and grinding question
Montreal
Is it me, or i try and turn and swing the knuckle and it doesn't seem to rubb anywhere. Could i do not need to grind? or it has never been seen on a 40 axle.
BTW i have a bj42 83, installed 30 spline longfield.
TY
I have installed them into a 1984 60 series and did not have to grind anything to make them fit.
Thanks poser, from reading different thread i concluded later model had the space.
yup, you should not have to grind anything with the later housing.....
if it goes in, no grinding is required.........
think
think
think
think
think
think
think
think
:hhmm:
think
think
think
think
think
think
think
think
;p
think
think
think
think
think
think
think
think
:idea:
think
think
think
think
think
think
think
think
:princess:
think
think
:doh:
:grinpimp:
my 69 had to be grinded on the trail to get the mini replacement in....hardly had to do any when i went to the 30 splines
i had to grind one side on my 76 no biggie, they work fine now so
Yeah - while it doesn't make any sense, my two longfield birfs seem to be slightly different sizes. Grind a bit on one side housing and one birf fits in fine, pull that birf out and try the other in the same side, and it doesn't fit - too big.
Anyone else run into this, or am I crazy?
78 and earlier housings will need grinding.
and, yes, headcase, you're crazy...just look at your name:grinpimp:
I have '84 FJ60 axles under my FJ55 and when I put my 30spl Longs in I did need to grind a little on the drivers side :confused: The passenger side was fine. But it wasnt a big deal at all
