Local For Sale/Wanted Section! (1 Viewer)
4.10 thirds I can help with. For what year land cruiser?
FJ60, let me check the flange pattern when I get home.
On 2nd thought, this would be as a spare, and if I blew the main one, I could always pull the pinion flange and swap it. It’s not likely what would fail.
i have a bunch of semi float rear axles shafts laying around, but do not recall the 60 series long side measurement.
From another Mud thread:
873 mm or 34.37"
521 mm or 20.51"
This was end of the shaft to the lug flange for a semi float FJ60
PM’ed you, thanks.
Still definitely looking for rear springs.
@FuglyYota I may have some. See pics. I don’t know if these are 40 or 60 series springs. Can’t remember what the PO told me years ago. If you can use them, they are yours for free.
Can you throw a tape measure on them along the length of the curve? And front center of the eye to the pin? That should be enough to ID them. Thanks much!!
@FuglyYota eye to eye along the curve was ~45”. The pin was 24.5” from one end and 20.5” from the other end. Hope that helps.
Found this on another mud post. I just measured mine, they’re about 47.5 long, 22 from one end, 25.5 from the other. Matches the table for FJ60 rears.
From what you measured, the dimensions seem closer to FJ40 rears? But not quite?
Well s***. :flush: I was going from center of the eye to center of the eye. Guess I need to try again :rolleyes:
That’s correct, should be center to center along the curve, like the tape measure will bend to Follow the spring. At least that how I got my measurements
Looking for a set of four tires for my FJ60 project. The tires on the truck are all dry rotted, surprisingly they are holding air (somewhat!!!). Could use a set of just four tires or might be interested in a set of tires already mounted on wheels that will fit the 60. Time to clean out your garage what do you have for me?????
For sale is a full set of battle born bead locks . They have about a dozen Wheeling trips. The fifth one is brand new, however I have lost about 4 nut inserts.
I just want different wheels and nothing wrong with these. I sanded all 5 rings (4 had Rock rash) and painted them green to match the fj40 color
Here's a link
Asking $1200 for the set
Located in Long island
Can take more pics of interest. These are old as 40 still under the knife
Not mine. In York, PA.
WTB a complete full float 80 REAR axle (non e-locker)
any leads, please let me know
Daniel
Have a set of OEM rear 80 mudflaps from my 95, also Toyota hood bug deflector as well as sunroof deflector if you want it.
Also a decent front bumper cover for 80
Best offer
Lancaster PA
I just finished selling off a bunch of OEM Toyota parts that I bought at auction when Futurecars, a local Toyota repair shop, went out of business. Most of the stuff is gone it was heavy with Celica, Supra, and Corolla parts. Hell the parts have been sitting in my shed and under my workbench for years! Anyway there is a right rear tail light here, the original box says it's for years 9/2000 and up. A little research says it fits 2001 and 2002 model years. Toyota part number 81550-35240. It has a broken lug that could be very easily glued in place but because of that I didn't list it for sale- and I have the lug, too. Would love to give it to a fellow club member who can use it. Let me know who has such a 4Runner and wants it. Free of course!
Selling a Better Built drawer box in excellent condiditon. This was used in the back of my 60 and 80 and worked well. Would probably fit in a 40 too.
It measures 37" long (across drawer front) x 26" wide x 10.5" deep. Ball bearing drawer slides, rubber diamond plate top mat, and t-handle latch system. Not sure these are even available anymore, but retail was in the $650 range new.
Asking $350 and can deliver to a club run if it helps.
