I'm in the process of installing new BP-51 shocks and SPC upper control arms on a new to me 2009 LC. I'm working on the front driver side and well I haven't been able to quite get the strut out. I'm having serious trouble lowering the lower control arm far enough to pop out the bottom of the coil over. I'v read a few different install instructions / methods. One suggests unbolting and disconnecting the sway bar linkage bolts and levering the arm down (OME BP 51 install directions). The other method (Icon Coil over instructions) suggest I loosen the lower control arm chassis bolts to free the lower arm bushing tension. Their instructions don't mention anything about loosening the sway bar linkage bolts or the steering arm bolts? They also don't mention this to be an issue?
Has anyone had the same problem (not being able to push the LCA far enough to pop out the strut. This evening I tried leveraging with a 4 foot metal pole and while i got closer, still no dice. I'm honestly not sure what's keep the LCA up - I suppose the bushings?
Here is a link i have going on EXPO - came here to mud for more technical knowledge.
Jah310 Land Cruiser Build - Expedition Portal
Any help, tips, experience would bd appreciated.
Thanks you! Thank you!
