Wanted Late model 12V 2H/12HT internal reg alternator or alternator core
Actually internal or external reg works for me. Had a few offers for options (thanks) but still holding out for a rebuildable original. Perhaps just a 12 v rotor with fine splines for the late vac pump?
I’ve got a couple of rebuilt units on the shelf, which version do you need exactly, beyond the regulator type.
There is also 2 different alternator bodies used (larger 4 bolt and smaller 3 bolt) as well as two different vacuum pump types.
Also have used 3 bolt, short pump, ext reg alt on hand.
Has rebuild tag from Japan on it, part number 27030-68120 30amp, 24v
You should be able to switch to internal reg fairly easily.
Sorry, missed the 12V part. That will be a tough one to find.
Still looking - one last try before going aftermarket
Apologies Lynchmob, not trying to hijack your thread but I sent you a PM about an alternator you had for sale last year. Haven’t had a reply. Just checking to see if you still have it. Thanks
