?This is just how ECUs work. Of course, if the sensor isn't actually doing a better job then the computer wouldn't gain any benefit, but if the sensor IS reading true more often, the computer will benefit in its monitoring and therefore its controlling ability.
When the computer samples the signal from this modified sensor setup it does not have to throw out nearly as many data points as noise because the sensor is not washing out in turbulence as often.
It only relies on the initial assumption of "improved signal from the new sensor" to be true. If a computer is seeing noise from a sensor as important as the MAF, its ability to control the engine is degraded. If that signal improves, its ability to control the engine improves -- there is no assumption about this.
The ECU does not have to be "changed" to take advantage of a cleaner signal from one of its sensors.
The software adapts to this and a computer can indeed create "more numbers" or perhaps more accurately a better data curve from a cleaner signal.
My 1995 is OBD II, but because of the year is usually sniffer tested, not plugged in. Since I have this mod, if I could get it sniffer tested, what would I be looking for? What readings? And what would it prove?
On my old truck and sniff testing in Washington State they'd give you a print out that showed carbon monoxide/dioxide, hydrocarbons, oxygen and NOx. If your state sniff tests NOx (I would think most would, since NOx contributes to smog), you're in luck. I would think if we were running lean enough to cause any kind of damage, we'd fail the NOx sniff test. I don't know this for sure though!
I wonder if our emissions test facility would allow me to test even though I just got new tabs through Jan. 10. I also wonder if they'd humor me and give me a sniff test if I asked. I know I've seen a print out of NOx emissions on a Washington sniff test performed on my old truck. They're pretty by the books at these state run facilities and probably wouldn't allow this kind of exploratory testing though.
To have access to just a couple tests! I'd run it with the stock MAF and the modified one a few times and see if we're getting high NOx with the new MAF. I need to make a friend at the emission test facility.... hmm.
well, there is over a 150 trucks out there running this MAF and I have only heard of one issue and that was a visual in CA. (trickyT)
Does everyone just scan the ECU now? I have to believe some have had the sniff test.
Christo has made up his mind that I'm wrong about how this MAF works and how the fueling system on our truck works. There is nothing more to be said to him about this. Repeating myself another 100 times is not going to change anything and only lead to more disagreement.
I've stated numerous times that if you plug in the vacuum line from the FPR that the LTFT% will shift about 18% and not to do it. I've even stated it here earlier on.
So what does he do, he plugs in the FPR and has an issue with the fact that the LTFT% is way out of whack at idle.
He now what's answers to his questions as in his mind this is evidence that there is a problem with the MAF sensor. He knows full well what my answer is but refuses to accept it.
The basic problem here is that he refuses to accept the idea that he may be wrong about how the 80 fueling system works. He is not ready to question his own understanding and ready to consider another opinion.
I didn't read some tech manual or discuss this with some trained technicians I reversed engineered it. To understand what that means, I did a series of tests and evaluations on the system to determined there effect on how the ECU managed them.
The first and biggest assumption he has made is that the vacuum line is there to maintain a constant pressure differential. I don't know where he got this idea but I can tell you with great certainty that this is not the case.
I could go into detail how me and Cattledog determined this but it's more clear to just say that on a boosted truck with a stock MAF sensor at WOT the engine is running crazy rich. He already knows this and posted it up way back years ago and showed this to everyone on a dyno chart he has.
So if Toyota designed the system to need a constant pressure differential why is it running so rich? If anything you want less fuel and a drop in fuel rail pressure is needed.
What Christo needs to do is accept the idea that I might be right, install the unit as instructed and then get out of his chair and actually eval the piece for himself. This way at least he can ask some pertinent questions. And if he is sincere about wanting to sell these then he needs to do this anyway to validate the product.
But I'm sure I'll come back here with a line edited reply from him telling me why I'm wrong and how he knows better.
And that is why I've not been engaging with him on this thread and a few others. There is no point to it and only leads to the demise of a thread.
This has created allot of confusion for most of the readers of this post.
The answer you seek christo are from another vendor and you should have worked this out in private.
You should worry more about some of your products that need attention over this thread.
Vendor to vendor this was just rude..
???I say some one do a dyno so we can put an end to this. I would hope a dyno for a stock truck with or without forced induction is already available. All we need is a complete 4wd dyno for a truck with the modded MAF and sensor.
Ain't no one out there???
I am sorry, but it is not an assumption. Here is the relevant pages from the Toyota training manuals. Please tell me where I assumed wrong?
If you leave the FPR hooked up and the fuel trims go up, it means the truck is running lean with the new setup. This can only mean that there is a calibration issue with the sensor and housing as to what the ECU is expecting, ie, more air is entering the motor than what is being reported. Your unplugging the FPR is masking this by increasing the fuel pressure.
If there is a calibration at idle, then there is an issue with the response curve of the sensor and/or the bore of the housing. Without doing a calibration on a flow bench and comparing the response curve with given flow between the stock and your MAF there is no way to know if you are correct.
Yes, you can monitor fuel trim and yes people are reporting better improvements, mostly because the truck is running leaner.
The bottom line is Toyota did not bandaid a inaccurate MAF sensor by connecting vacuum to the fuel pressure regulator.
I do not know why Toyota made the truck run that rich. Adding forced induction to a truck that was normally aspirated has it issues, and the overly rich condition is one of them. You started this development for your turbo build, and that was a good thing. However stating things about why mods are done that is incorrect is not.
We will do that when we get the time, however as the vendor of the product, you also have a responsibility to post the correct info, or at least obtain it.
Yes, and I am sorry it has come to this. But facts are facts.
