Well, I'm pretty confused now.
I have a few questions for anyone willing to answer them. Christo, Rick or anyone else.
What sensors does Toyota use and how do they determine fuel pressure on 1998 and newer engines, which, as shown, does not use the same MAF sensor as our 1995-1997 engines.
It appears to, if I'm reading the diagrams right that Toyota uses the same fuel pressure regulator with the same vac lines hooked up on 1998 and later models that do not use the older "inferior sensor". If the vac line that we disconnect for this mod is mainly to compensate for the inferior sensor, why would Toyota leave it hooked up in later models where this sensor doesn't exist?
How does TRD or Toyota compensate for the added air flow of a supercharger with their stock unmodified kit? How do they prevent a lean condition when adding all that airflow that the system was never originally designed for or expecting? Do they rely on the computer to make all adjustements or are there additional parts and sensor modifications made?
If we're relying on the 02 sensors more than Toyota intended (assuming I'm reading this right) then what happens when one or both 02 sensors fail or get old and produce false readings?
What is the real danger here in Christo's mind, just so I understand. That the sensor itself may not be reading properly to the computer and that we are running lean all the time, or is the real problem the disconnected vac hose and how that affects fuel pressure both at idle and at speed?
By the way, read this thread I started in the 70 series section. Someone was kind enough to post some nice detailed picturs of a 2008 (yes 2008) 1FZ-FE engine. Note the following. That there is no MAF sensor in the air hose at all. And that the vac hose that we capped off on this mod is still very much in place just like on our rigs. As far as what Toyota uses for a MAF sensor, the EPC indicates that they have a temp sensor (temp sensor only) in the air pipe somewhere. (I don't see it in these pictures.) So, unless this temp sensor happens to replace the MAF sensor of old, I don't know how else they measure air pressure.
https://forum.ih8mud.com/70-series-tech/264657-1998-later-1fz-fe-engine-questions.html
At this point, being admittedly very ignorant on this issue and the testing results, my concerns are that Toyota continued using that vac hose on models that have nothing to do with our 1995-1997 sensor. So what does that mean and how does that affect those of us that have removed and capped off that hose?
