hope these pics help...
Nope
jesus. nice.
Just slot the fronts..
jesus. thanks woodsman. sorry it should obviously be easier.The front cut slots are for New bolt to go thru..original hole is where dimple goes
On the back/rear end of plate, bolt goes thru original hole
So, I’m worried it would getting rotated the wrong way... to be clear, as you lift the truck and the axle drops, it rotates so that the pinion points up higher towards the t-case. The centerline at which the knuckle pivot (caster) rotates so that the the centerline points forward instead of vertical.
caster correction plates rotate the axle so the pinion should drop. Make sure that is what is happening before you drill holes or grind.
I know this is probably obvious to many but just wanna know if we’re all on the same page
@hotwheels2017
Here is how slee and others do it, I don’t know how land tanks are
First pic shows the notch
Second is the plate
Third pic is the top hole you use that hole for the top hole of the plate
4 pic is the pass side, you have to use two small bolts to mount on that side
Rear hole of the plate goes through the original hole 🕳 n the back
With slee you do not drill any holes you only notch the front
Test fit everything first..... then weld em up on the front end...I welded back ends as well
When welding, make sure and bolt em up without control arms hooked up... heat will burn rubber bushings....when cool, bolt up control arms
Send um back and order Slee’s he provides instructions
THANK YOU for all the help.
btw, the tip on leaving the control off when welding is probably a good one to put in the instructions. might be there but i missed it. can i ask how you make sure you don’t misalign it when removing them bolts and the control arms?
The dimple will keep it alined and the two bolts...lightly tighten bolts for welding though, don't torque and pinch,...you can use old/original bolts for welding
Some people might just weld em on with control arms on but not sure thats good for OEM bushings......landtank or Joey should know.
Do you have the plates on hand? If so start on the right side of the axle as they can only go on one way. Then do the left side mounting them in the same direction.
installing these plates really doesn’t need some elaborate set of instructions. Once you have them in hand it will make more sense.
Not Slee brackets, but it might help...
