- Thread starter
- #21
When I was there checking it out, I put it neutral and let it roll a bit, nothing alarming. As for the fluids, I did check the coolant and it had in red coolant (which must be Toyota brand coolant, unless there are other red coolant brands?) and I checked the oil on the dipstick which was filled up and looked right.I would check the fluids for signs of issues. Is the motor oil clean with no milky residue? Coolant looks clean (you can drain a small amount out if the petcock on the bottom of the radiator into a jar), transmission fluid looks/smells ok? If it's on flat ground, can you roll if a few feet in neutral and make sure it doesn't sound like broken metal? If I didn't see any other issues and I didn't mind parting it out if it came to that, I would take the risk personally. As others have said, it might be something easy. Then again, it could be that they hooked up the jumper cables backwards and fried something electronic. Can you tell what clicks when you turn the key? If it's the starter then you've either got bad contacts in the starter or a bad battery or starter cable connection. If it's a relay clicking then could be electronics. Ultimately don't pay more than you would for a car to part out, and you either part it out and do ok or get lucky and get a cheap car to drive.
Im pretty confident that the clicking sound heard is coming from the starter, because the sound is coming from the top of the engine.
Say they hooked up the jumper cables backwards, what exactly would that do/ break? Couldn't find any solid answers online. Also, just a reminder, everything electronically in the truck worked. Lights, windows, horn, you name it.
