can anyone help me proof this list for a knuckle job?
A. what am i using to grease seals? anyone know which seals are getting greased?
B. also somewhere i had a note i could use valvoline palladium moly for wheel bearings and spindles but wondering if it's better to use the Mobil 1 Synth Red.
C. does this little cheat sheet look right? should i lube the splines with moly?
any other mission critical items?
D. how does this list look?
THANKS
DIFFERENTIAL OIL TYPE: hypoid gear oil API GL-5
OIL VISCOSITY:
above -18dC (0dF): SAE 90.
below -18dC (0dF) SAE 80W or SAE 80W-90
>REDLINE gear lube 75W-90,
>MOBIL 1 gear lube,
>AMSOIL gear lube,
>CHEVRON delo gear lube (ESI 80W90).
WHEEL BEARINGS and PINION BEARINGS: lithium base wheel bearing grease, NLGI No.2
> Valvoline Palladium #2 3% Moly, Heavy Duty (HD) Grease 14.1 OZ Cartridge
> MOBIL 1 Synth Red
KNUCKLES (2X): lithium base wheel bearing grease, NLGI No.2
> LUCAS red N tacky grease 14 OZ cartridge or tub.
SEALS + BUSHINGS ?
THANKS
OIL VISCOSITY:
>MOBIL 1 gear lube,
>AMSOIL gear lube,
> MOBIL 1 Synth Red
SEALS + BUSHINGS ?
