Key for 1974 FJ40
Toronto, ON
Does anyone knows what is the Blank Key part number for Toyota OEM ignition key on 40-series?
My local dealership doesn't have any in stock and they need to special order it, meaning I can't return them if it's not the style I'm looking for.
I'm interested in the metal key with small plastic head, similar to this one:
Are there any types of logo available, "TOYOTA" word (as the one pictured), Toyota "T" logo, "TEQ" word,...
@AlexJet :
I don't know if this key blank looks like your picture, but the ignition key for the US model (assume Canada is the same) is 90999-00054, which has been superseded by 90999-00085, US$9.33 dealer list price.
I'm in need of keys, too. Not sure what I'm going to do, as I have no key from the PO and the gas lock has no code. Probably going to have to pay the locksmith to go old-school and build a key from the scratch. FWIW, not sure the newer plastic head keys will fit into the older lock cylinders, even if the actual key portion is the right shape. Those old, flat, metal key heads sort of fit into a similar female shape on the lock cylinder. The plastic head might not fit. Or, I'm wrong. Probably more likely.
I bought the SOR blank and the Ace Hardware nor Home Depot would cut it, so I have a paper weight on my tool bench. I found a 60 year old locksmith shop who had the blanks in stock and cut me two keys for around $12. He's in Walnut Creek, CA. If you can't find another solution, mail them to me and I will take them to get cut and then mail back.
The Black Nylon Top OEM Toyota Key U have in the photo above part # is 90999-00212 , It retails for approx. $16 at any Toyota Dealer
I just picked these up friday for a lock re-code / re-key job on a 1/79 FJ43L-KC , So there still available
This Key Blank will fit All 1975-1991 land cruisers , Ignitions & side doors / fuel doors
I have a few 1975-1991 NOS OEM Key blanks Available ,
- 90999-00031 ( Mini Wallet Key blank style ) TEQ LOGO & TOYOTA MOTORS logo's
- 90999-00046 TEQ logo one side / TOYOTA MOTOR & TEQ LOGO on the other side
- 90999-00030 TEQ LOGO & TOYOTA MOTOR logo both sides ( This is A Full Size Key )
- I CAN Also Cut Your Key's to Your Factory TOYOTA Key CODE Using my Shops Dealership - Type SST Computerized key Cutting machine
- Your Factory Key Code Is stamped on your passenger side lock cylinder like this example
Not on a '74. No external passenger lock. The only locks are the rear hatch and the DS door (both single-sided key) and the ignition and fuel door (double-sided key). Sadly, no code on the fuel door lock cylinder. Even sadder, if you don't have a key to get the ignition lock cylinder out of the steering column, you are SOL.
The Original 1974 Keys them self's ,( ones sold with any new Toyota Vehical , Both single sided & Double sided Ignition , doors , rear hatch etc. had the key codes stamped physically on them
do U have any original keys ?
I have had to drill out a ignition Column Cylinder before , No fun :(
I have a hatch key that works, no door key, and no ignition/fuel key. There are codes stamped on the outsides of the single-sided locks.
I also have a complete set of Dealership SST master keys for Double sided 1973-1991 FJ40 , FJ55 , FJ60/62 / or commonly refereed to TR-33 lock smith's " Test Keys "
These are a full set of ALL Factory Toyota Key Codes ,
One of the 250 pc. set would correctly engage & open your ignition cylinder on your column like U mentioned ,
I could then send U a working set of keys back in the mail i cut to the matching corresponding key code
all U need to do is remove the main Magnesium Ignition lock cylinder housing from the main steering column witch is held in by 1 snap ring , and fairly simple to do
PM me for more details
RAGINGMATT, PM sent
I'm planning to get the ignition key this weekend.
Does anyone has an instructions on how to remove the ignition lock out? Do I also need to pull the actual lock cylinder out of the ignition lock? What is the procedure of doing It? Don't want to break anything, so any help/advice is much appreciated.
I took the Ignition Lock out from the column, but how do I remove the cylinder from it?
I'm having trouble to find out way of finding the right way to take it apart.
Does anyone knows how to take it apart???
