Japanese V35A-FTS Bearing Issues (10 Viewers)
Toyota being the global company it is has standardized practices and processes in multiple plants. So if there is an inherit process error it will be agnostic to location.
They excluded Hybrids… but plenty of Hybrid tundras have had the issue. What goes into a proper filing?
Recall only includes 2022-2023 non-hybrid models. However 2024 models have the same issue, as do the hybrids. I also find it hard to believe that machining debris were an unknown issue for 2 years, AND both Japanese (LX) and American (tundra) plants were impacted. It just doesn't add up. But that's just my opinion.
I was really looking forward to buying one new and driving it for 20 years worry free, like the previous owners of my 80 and 100 did when they bought it new. Will likely lease something for the next 3 years for my wife, I'm hopeful that this issue will be resolved by then.
If anyone wants to nerd out on this (I found it interesting,) you can read the official NHTSA report here:
Overall link to additional documents:
I'm not an expert but interesting points that stand out to me:
1. This is specifically labeled a "Safety Recall." It seems like the NHTSA only deals in defects that could injure or damage people/cars and impact highway safety. Other "recalls" specific to Tundras like broken seat trim, poor alignment/tire wear or wind noise aren't on there. Probably just TSBs?
So when you look at it that way, check out section 2. (2) - "If engine failure occurs on a Hybrid vehicle, the vehicle continues to have some motive power for limited distances and the driver receives a continuous audible warning, warning lamps, and visual warning messages."
In terms of safety they're not exactly claiming that hybrids are good to go, they're saying that if your engine dies at 70 you have a better chance of coasting to the side of the road vs a non-hybrid. Reading between the lines, they're saying hybrids can also fail.
2. In section 6 you can read a chronology of events. Here's a summary but there's a decent amount of info there:
- March 22 - Dec 22: Three engines failed. Toyota looked into it. Couldn't figure out what happened. They hypothesized that it was machining debris so they implemented cleanliness changes.
- Jan 23 - Aug 23: Toyota continued to watch the market and analyze engines to see how their cleanliness changes were doing.
- Sep 23 - Jan 24: Toyota saw an increase in engine failures (We can assume that a large portion of the 824 verified failures happened here between 2023-2024.) They also started investigations into the design of the engine (including the durability of the crank bearing itself) and the installation process in the factory.
- Feb 24 - May 24: Investigations showed that even some good engines showed bearing degradation but no failure. They completed their investigation and "The results showed that the damage that was seen on the bearings was from debris created during the engine machining process, and that there were sufficient debris sizes and amounts present to cause a bearing to fail."
Then they announced the official recall last month.
3. In this document, Toyota states that "All known owners of the subject vehicles will be informed that remedy is under investigation and that they will be contacted when further information is available" and in the official notice to dealers, they say "Toyota is currently developing the remedy for this issue."
The timeline makes sense to me, with Hybrids of all years and 24s, both Tundras and Seqouias, that have failed. They implemented changes in Dec 2022, but haven't made any changes since then - at least none that I could see in this report. They made those first changes and then just kept analyzing and studying the problem. And as noted, they don't have the remedy yet. So it may be a little while before they have the bugs worked out of their machining debris issue.
Interesting information. I wonder if they can find a remedy and implement it for the 2025 models...or is that too short of a time line? Would consider leasing a 2025 at that point and purchasing at the end of the lease, if they can pull that off.
Greetings. I'm the tech in Kai's video. My biggest concern is that even though toyota / lexus are warrantying engines due to debris, they will absolutely under no circumstances warranty anything else unless there's "visible" damage. This means the same turbos that have had debris going through the center cartridges will not be replaced.
We've had a v35a with absolutely wrecked camshafts and cam carriers which were replaced under warranty, but they would not let us replace anything else.
Best of luck to LX600 owners !
Do you think this an issue intrinsic to the engine design, or a manufacturing issue?
Can you see this issue get resolved in future model years? Any other issues you’ve noticed with these trucks?
Would love to get into a LX600 in the next couple years, and honestly I was waiting because I didn’t want to be a guinea pig. I appreciate your expertise.
I just got into one, a couple days before the recall!
@NoClue What are my odds? I did extend the warranty to 8yrs/100k
Think I should extend the warranty on my 4/24 build date? Anyone know if they changed any internal parts?
I never buy that stuff or wheel insurance etc. I just put a few thousand miles on them and start modifying them.
Nobody knows.
Wait to see what the remedy is. It may be extended warranty. If 24s keep failing, they'll likely fall into the recall too.
Yes great info. 11/21-1/24 same partial engine and short block part number; part number changes after 1/24. 1 and 4 main bearing part number expires 4/24. A camshaft housing part number changed in mid 2023.
Mine was built 2/24. Any way to tell which engine part number I have?
That video has the part number.
I wouldn’t be concerned at that date. They probably have the revised parts in it as they would need to be stocked on the new part number in order to replace it?
thanks for sharing! Do you have any other photos to post?
I verified with my dealer that mine is tagged to the recall. The dealers have not been informed to what the remedy or diagnosis process will be. I did an oil change today and will be sending a sample to blackstone this week. The wait begins….
Analysis back - LX has 23,500 miles on the clock.
Perfect timing, I was just thinking about this earlier today!
They are quite backed up. So know that you've got a 3-4 week wait when the sample is received. The good news is that there is no noticeable silver; which was the speculation or indicator on the tundra forums.
