This should not be this complicated.
Put the thermostat back in after to verify it is working correctly, or else install a new Toyota OEM one -- they are inexpensive.
If your temps are climbing up while in traffic or stopped, then you have a potential problem with your fan clutch. If it's original, just replace it and be done with it.
If the radiator was replaced with a new one and you have no other evidence of a blockage, cracked block, cracked head, bad head gasket, etc. then you've just narrowed your problem right to the fan clutch.
Hope this helps.
R
Hope this helps.
R
