Southeast Overland
Get lost! Go explore!
Stock gauges vary so much that I would not use any reference temps besides "red is too hot." anything else is an assumption that is misleading at best and headwarping at worst.
since I've ditched the stock fan & use the Contour e-fans, my rig runs between 190 & 200 w/ AC on @ mid 90 degree air temp.when i install my gauge.....what temp is too staring to get too hot? 215 or something like that
I used the stock sender location. The probe fit fine and I didn't have to use any special fittings.Where are you guys putting the sensor or sending unit for a second gauge?
Is there any good spot to add or are you abandoning the stock gauge and using that sender location?
Cheers,
Dave
doesnt the alternator need he pump in place with that bracket connected to it..............thats why i wanted to keep the pump.
yes, the Help section in the local auto parts store has them. They are heater hose caps, 3/4" ID I think.do you just cap at air housing and the metal pipe?
yes, 14v measured at the back of the alt.also is the alternator getting enough pull minus the air pump part of the belt?
my guages came with some fittings in the package. I didn't need to buy extra ones.yea thats why i am will be getting some fittings to fit my gauge today.
wait until you install the mechanical guage. It's pointless to troubleshoot with the stock guage.when i hit the gas and speed off( lol) my truck temp goes down and then after i let off it goes back to right under 2/3's mark. does that sound like definite fan clutch slippage? i replicated this situation a few times- Cody
dump the stock guage and DONT get rid of t he stat
