Go ahead and look up the intermediate shaft and order and replace it. That and the rag joint will tighten up your steering. Yours looks a bit crunchy.
I don't know what any of that means. I just posted the follow-up to my saga. Are any of the parts I mentioned related to that?Go ahead and look up the intermediate shaft and order and replace it. That and the rag joint will tighten up your steering. Yours looks a bit crunchy.
See my pic for more info. The strut removal...I typically pull on the lower portion and use the entire strut at a lever.I don't know what any of that means. I just posted the follow-up to my saga. Are any of the parts I mentioned related to that?
Thank you for your quick reply & advice!!!
Ohhhh okay I’ll add that to my Spring to-do list. Gotta research more. Thanks!!See my pic for more info. The strut removal...I typically pull on the lower portion and use the entire strut at a lever.
Looks like I went deep into the suspension rabbit hole.. much deeper than we anticipated!Looks like you've got it! Last time I did that I used a sawzall to slice off the top hat. A bit of a pain but it worked! Just replaced my front coil overs under warranty and had to to it again for one side, due to a couple of the smaller nuts being stripped on the studs.
Regarding the pre-built brake lines, I need a couple for my rear axle and have not been able to find them prebuilt (OEM or aftermarket) You may need to just DIY bend some. You can usually get pre-flared universal hard brake lines sections in various lengths from the auto parts stores. Otherwise, you'll need to buy a roll of tubing, fittings, flare tool, and cutter to make them yourself. I have been putting this job off but am probably going to just buy a flare tools (a good flare tool is $100+). For a rustier GX you'll likely run into this problem again, so I'd just get the flare tool unless you can find a universal pre-flared line that is really close to the length you need. If you get desperate, you can also buy a longer universal line than needed and put a loop in it somewhere.
For the bracket attached to the frame, I'd recommend DIY'ing one out of a piece of steel flat strap. You can pretty easily bend the flat strap in a bench vise with a hammer and then drill holes in it. Otherwise, might have to get one from a junkyard if Lexus does not have it easily available.
No problemo! It took me a few hours to get all the correct info sorted. If it only helps one person, it was worth it. It’s the official Lexus parts website. The others don’t have the diagram so maybe that’s why.Thanks for posting. I must have looked at the wrong site because I could not find those for mine before. Rears are only $23 or so for side! Will get them from my local Toyota dealer.
You saved me a $120 flare tool, $50 in line fittings, and hours of time. Beauty of forums!No problemo! It took me a few hours to get all the correct info sorted. If it only helps one person, it was worth it. It’s the official Lexus parts website. The others don’t have the diagram so maybe that’s why.
I looked at my order that I cancelled because I had them made by that company and yeah, these are the part numbers.47313A (LH) ------ I believe these are the ones I got SS hoses for so I didn't order this part.
47313A (RH) ------- Same as above.
In hindsight, I regret not creating a new thread and classifying it as *builds*, but oh well.
I've done quite a few things since my last update.
- I degreased, prepped, and painted the newly visible parts of the frame with por15.
- I got my eibach front strut/shocks assembled at The Custom Shop in Queens, NY. Great guys. They squeezed me for an hour despite being fully booked for 2 weeks. They also informed me the KYB top hat bushings didn't fit, so they installed 2 from some of their spares. I would've been screwed had I done it at home.
- Installed the JBA UCA's
- Replaced driver side CV Axle with Cardone 66-5235HD. OEM will be rebooted later
- Installed new steering knuckle, Tie Rod End, ABS Sensor, & reinstalled brakes on passenger side.
I'll finish up the driver side tomorrow.
I misplaced the little bol
that attaches the ABS bracket to the UCA, so I used a zip tie for now. I'm absolutely dreading the brake line fiasco. Le'sigh
Looking really good! Love the color way you have going. I need to get some more cosmetic work done more than anything, but major respect for this! There are some other things I need to fix, like the steering wheel squeak on start, or a small squeak when moving at idle speeds. Some maintenance work to be done here and there, but my biggest gripe is the sunroof tracks have basically deteriorated and I can no longer open my sunroof. Dreading taking it apart, but the shaking and vibrations that is coming from it is driving me crazy. We'll see how it goes over here!
Heh, I try not to even open my sunroof anymore. I always wondered why my truck was so cold in the winter, and I couldn't pinpoint where the crazy wind noise was coming from. Turns out the sunroof didn't properly close last time I used it.. mine might be going down the same road.Looking really good! Love the color way you have going. I need to get some more cosmetic work done more than anything, but major respect for this! There are some other things I need to fix, like the steering wheel squeak on start, or a small squeak when moving at idle speeds. Some maintenance work to be done here and there, but my biggest gripe is the sunroof tracks have basically deteriorated and I can no longer open my sunroof. Dreading taking it apart, but the shaking and vibrations that is coming from it is driving me crazy. We'll see how it goes over here!
