I hope thats a mock up, that or stay off the road.
You need way heavier material.
Your center pivot looks damn close to the panhard bar. Will it touch flexed either way?
Here's what I'm starting with. This is a 1/4" I-Beam, which is probably way stronger than I need. The shape of the I-Beam should keep it from twisting, which is a problem when using tubing (square or round) or just simple plate
So Nay and others are wrong with regard to rockcrawling and the front of an 80.
Just speaking from a point of general knowledge, as I am in no way an expert, but an I-beam does nothing (or close to nothing) for twisting, it does support more weight along the length of the beam than a piece of flat stock. I suspect, this may not be the best material for the job.
You DO know that people are out there with long term installs using a bit smaller than 1/2" plate?
I-Beam is not designed specifically for withstanding twisting, that is true.
BUT, in comparison to flat stock, it is MUCH stonger in all directions, including twisting.![]()
I know a few things about fab and suspension and all I see is a failure with the material you are using.
Just the grade of steel alone will fail with the weight of the 80 in non ramp wheeling situations.
1/2 or whatever, you are creating a death trap unless you go to rated quality steel.
And I know a little about 80's and wheeling in "rock" terrain, you will never match a Mini or SAS conversion. Not gonna happen, to big and heavy.
For what you are building you should be using plate steel of very high quality with dimple dies for rigidity
the I beam will not work
look at the suspension pieces built for buggies and desert trucks and take a long look at what your doing.
......you will never match a Mini or SAS conversion. Not gonna happen, to big and heavy.
I used to believe this also. if your mini is linked then the argument stands. BUT the vast majority of minis are underpowered with leafs and shocks that are not tuned. Bring it
Some cool pics I just got sent of a 100 series in WA
from what i heard he is maxing out the long travel FOX shocks! (way cool)
