SCEET Tubing Solution
I used 3.25" diameter aircraft SCEET tubing to replace my defuncted intake hose. I purchased the tubing from Aircraft Spruce but any aircraft supply should have it. 3" was a little too small so I went with the 3.25" diameter. I did have to add an additional layer of reinforcement to the inside to provide a snug fit. This was in addition to the external layer of reinforcement. I just used strips of old SCEET material for the reinforcement and some red RTV to glue it all together. Once the tubing was cut to length and the inner strips glued in place, I inflated a balloon inside the tube to keep the layers tightly together while the RTV set up. I then added the exterior strips and wrapped the tube with saran wrap while the RTV set. This minimizes the mess and provides a nice finish.
The first photo is of the old intake hose and the materials that I used. Second shows the old vs. the new. And the final one is of the installed hose. I've been running the hose for a year with no signs of deterioration. As an added bonus, the SCEET is flexible enough to allow removing the air filter without disconnecting the hose.
