Living in the Past
One thing I would do is buy the non-split type armaflex. It is a little harder to install but it will hold form better. The type you peel away the tape and stick together will later split at the bends. Use to buy it in 6' sticks. The most you would need would be two sticks. I guessing 5/8" with 3/8 wall would be good. Check the OD of the pipe to be sure. Before installing sand off any ruff spots on the pipes. This will let the armaflex slide on easier. Also plug the end of the pipe before installing. Otherwise you will get a black dust inside the pipe.
