I installed front and rear Terrain Tamer brake pads that I got from my friend Rob at Odd Iron Off Road. I actually put OEM pads on my 2010 Subaru Forester this morning and decided while I already had all the tools out and setup that I would go ahead and install the Terrain Tamer pads I had waiting on my 2005 LX470. Fairly easy job. The pads were a perfect fit. They come in a terrain tamer box with a pair of front and rear pads that are sealed in plastic. each pad has a shim on the back of it. I reused the clips on the front and rear calipers. The pads installed easily without any issues. Everything fit perfectly. I took the LX470 for a test drive after completion and it stops very well. The powerstop pads which were placed on it by the previous owner did not seem to grip nearly as well. The vehicle seems to have better stopping power, I will keep you updated. My wife drives this vehicle 80% of the time so I will see what she thinks of the pads and update this thread. Overall I am very happy with the terrain tamer pads at this time. I used generic Valvoline dot 3/4 fluid to flush the system which I assume also helped some. If you are in need of new pads I would consider terrain tamer pads. I have a pic below of the item numbers.
